buying rimmies.... finally, need input
Old Dec 29, 2002 | 11:12 AM
Loneshark's Avatar
Vehicle: 2000 Tiburon
Default buying rimmies.... finally, need input
can anyone recomend a good size 17" rim and offset so that the tires wont rub
Old Dec 29, 2002 | 12:53 PM
Spiffywerks's Avatar
17x7" will be your normal size for 17s.
Stock offset is +42.
I use +40 on my setup, no rubbing. Eibach 1.2" Lowering Springs.
According to Random, you can run up to +35 offset with no rubbing. Just make sure at +35 you have 205x40/r17s because 215x40(or 45)/r17s will cause you to rub due to the slightly wider diameter tire.
Old Dec 29, 2002 | 11:30 PM
Loneshark's Avatar
Thanks Spiffy, you the man,
what about 18's, there was a red tib i saw at xtreme autofest with gold 18's, i didnt ask the offset size or if they rubbed, but i bet they did cuz they were like 1/4 inch from they wheel well.
40 is a nice offset but, what will make the edge of the rim look flush with the fender especially in the rear, they look so tucked in, would a 30 be totally flush?
Old Dec 30, 2002 | 01:30 AM
ELANTRAVISION's Avatar
Motegi's MR7's, which I'll be getting in the summer are 17x7, 40mm offset. Compared to my old ones which were 16x7, 42mm offset. I plan on wrapping the 17's in Dunlop SP Sport F901's, 215/40/17. You probably won't find anything less than a 38mm offset, not on rims that are going on a FWD vehicle. At least that's what I've been told.
Don't forget that the stock rims of the Tib are probably 6" inches wide, compared to most 17" aftermarkets rims, which are probably 7. Even if you had the same offset, half of the difference would bring the setup closer to the fender.
[ December 30, 2002, 08:34 AM: Message edited by: ELANTRAVISION ]
Old Dec 31, 2002 | 02:16 AM
Loneshark's Avatar
MR 7's are pretty nice, my friend has those on his galant, I was thinkin of tenzos white 5 star rim; the RS 5 On my cobalt blue tib??? yea boy will look hot
Hey Spiffy, can i run 215's on a 17" with no problem??
[ December 31, 2002, 09:44 AM: Message edited by: Loneshark ]
Old Dec 31, 2002 | 04:14 AM
cringe's Avatar
I got 215/45/17s no rub
Old Dec 31, 2002 | 05:58 AM
Julez's Avatar
Vehicle: 2008 Accent
Same here, no rubbing ever.
Old Jan 5, 2003 | 09:35 AM
Loneshark's Avatar
what about... in GOLD,
to get that wrx blue with gold feel...
minus the turbo..., and the awd..., um, and the gearbox... geez what am i trying to do here rolleyes.gif
Old Jan 6, 2003 | 06:10 AM
Lowridin Accent 00's Avatar
Yeah I would go with 17's or 18's, that is just my opinion.
Old Jan 6, 2003 | 06:25 AM
cringe's Avatar
bleh to gold rims! never EVER looks good on a car, IMO.
