Brakes Squeeling
Old Aug 18, 2006 | 07:38 PM
12SecRD's Avatar
The driver side front brakes(only) have been squeeling the past couple months.
First brake job included resurface the rotors and install new Hawk brake pads. 3-4 days of driving squeeling is back.
Get the brakes service thinking maybe the clips are touching the rotor somewhere. Everything looked good replaced clips just incase. Tried anut squeel greese on back of pads Same thing squeeling, squeeling.
Next brake service replace front pads thinking the Hawk might be just to hard and causing the squeel. Same thing squeel.
Next service replaced the rotors and installed a new pair of Hawk pads. 3-4 days later squeel is back and like before only on driver side.
Any suggestions on what else it could be? Or what to try? Caliper ?
This is getting on my nerves, and costing me $$$ thats not fixing the problem.
Old Aug 18, 2006 | 07:39 PM
lube up the calipre slider bolts?
Old Aug 18, 2006 | 07:40 PM
12SecRD's Avatar
Yea they move freely....
Old Aug 18, 2006 | 07:43 PM
it sounds just like the caliper is getting stuck. if its not the slider bolts, then its probably the piston, and would more than likely be easier to just replace the whole thing.
Old Aug 18, 2006 | 08:13 PM
12SecRD's Avatar
forgot to add squeeling is only when brake is partially pressed. During hard breaking no squeeling
Old Aug 19, 2006 | 01:57 AM
Rd1tib's Avatar
i had the same shiz when my pads were installed slanted and because my rotor was not resurfaced before i installed the pads.
