beta swap- new suspension required ?
Old Oct 17, 2012 | 04:41 PM
Antonyr123's Avatar
Vehicle: Hyundai Accent
Default beta swap- new suspension required ?
First off.
i fitted a beta engine into my 1.3 alpha Hyundai accent (47,000 miles) had from new.
Problem is when i tuning the ecu yesturday driving it i noticed i lost the smooth ride i once had and it started to be alittle harsher and noticed every bump in road.
Is there much weight difference between the 2 engines and should the suspension be firmed up ?
Old Oct 17, 2012 | 04:45 PM
you have a suspension designed for a cheap eco-shitbox
then decided to add a motor roughly 100#s heavier (probably more with everything else you added to it for the swap) that doesnt even include the turbo parts
lets put it in math terms
fail sh*t suspension
+ 100lbs
fail+100
Old Oct 17, 2012 | 04:55 PM
Antonyr123's Avatar
i knew engine was heavier because i was the one who lifted it into place.
Are there any commonly changed parts after a beta swap.. All the older posts iv read about this all have dead links.
Old Oct 17, 2012 | 05:04 PM
at a MINIMUM id probably look at some heavier springs and better quality struts, i believe h&r makes a spring set for the accent, eibach used to but im not so sure they sell them anymore
be careful with lowering springs though, the heavier motor probably already lowered the car some, so a 2" drop can easily become a 3" drop so keep that in mind
if it were me, id pick up the set of ksports listed in for sale by fintile (assuming you have a LC accent that is) that way you can have a heavy duty suspension while maintaining stock ride height or slightly lower plus its adjustable for the track and he has em listed at a damn good price
although its sorta a trade off, while you will have more traction be better off in the long run, a stronger suspension WILL have the trade off of being harsher than when you had the stock motor/stock suspension setup
Old Oct 17, 2012 | 08:35 PM
Whatever you do, stay away from the cheap $75 sleeve coil overs. If you get better struts like KYBs, you should be ok though.
Old Oct 18, 2012 | 02:02 PM
Antonyr123's Avatar
THanks Guys.
I'll go and have alook in the sale sections. The only problem i have. Being from england the Shipping fees for heavy good can be 100s of dollars. There is not one. Uk dealer on ebay for any setups
