Anti-seize on lugs
Old Nov 17, 2010 | 01:08 PM
tibby01's Avatar
Vehicle: 2001 Tiburon
Default Anti-seize on lugs
Is it safe to put anti-seize on your lugs? I always try to torque them properly, but I know a few people who do put it on and was wondering if its a good idea or not.
Old Nov 17, 2010 | 01:57 PM
i always do. i haven't had any problem for years.
Old Nov 17, 2010 | 03:20 PM
UrS0NvS's Avatar
rule of thumb, no. I always did until i watched a program about it on powerblock.
said something about stretching the threads and giving improper torque specs.
Old Nov 17, 2010 | 03:38 PM
i think that's if you over-tighten them because the grease offsets the torque. but if you tighten them just right, i don't think the threads will really move. that's only my assumption though.
Old Nov 17, 2010 | 04:11 PM
turbosocks's Avatar
i always used it on the tib without any issues. anti-seaze makes life alot easier. love that stuff.
Old Nov 18, 2010 | 08:35 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
No. You don't use anti-seize on steel to steel threads. Proper uses are steel spark plugs in aluminum heads, or steel O2 sensors into stainless exhausts.
Old Nov 18, 2010 | 02:36 PM
Regit's Avatar
Vehicle: 2000 tib
IMO neverseize should go on the back of the rim so it falls off the hub easily ,not on lugs.
Old Nov 18, 2010 | 02:58 PM
anti-seize steal-to-aluminum yes, but lubricating the threads in general? i think it's much better option than having a lug lock up on you or rust in place.
Old Nov 19, 2010 | 04:55 AM
SR Tech's Avatar
Vehicle: 2011 Tuscon
^^That's where mine goes.
I've yet to have a lug "seize" on me or be on there tight enough that my impact couldn't get it off. If i ever do, i know where to find a good cheater bar. If i break the lug stud in the process, i know how to replace it
