Airride questions? (Split by Moderator)
Old Feb 5, 2004 | 04:17 PM
blue2000's Avatar
Vehicle: 2K Tib
I split this post separate from the sticky so it will be "on top". One of you air ride suspension folks, help this guy out, please?
Old Feb 5, 2004 | 08:32 PM
BigBoi's Avatar
GUILTY!!!... OHHH GUILTYY!! WHERE ARE YOU?? Help this poor guy out. LOL
here are some links that might answer some of your questions...
http://www.hyundaiaftermarket.com/noncgi/u...t=000090#000000 (has sites to buy airride from)
http://www.hyundaiaftermarket.com/noncgi/u...t=000008#000000 (has technical info)
hope this helps
Old Feb 7, 2004 | 12:17 AM
Guilty's Avatar
Vehicle: Custom Wagon
Ok there is one place that makes a bolt in kit for our cars. It's Aim Industries. The kit runs about 1800.00 or so. It might a little low or higher. Because they are making their own struts now before they had to buy them from the dealership and then install the bags.
It's my personal opinion to get BAG STRUTS not cyclinders you'll get a better ride out of bag struts. But cyclinders are faster but the ride is harsh.
The bag struts will bolt right in no problems. I was the 3rd tib with airride I've had my airride for two years and have never had a problem with them. You can adjust the height while driving do to a on board compressor which fills an air-tank. Most tanks are 6 or 9 gallon tanks.
You can make it quick by putting larger air-lines and valves that can hold more psi. I'm running 1/2 inch air-lines and 1/2 valves. The most important thing is to remember to make sure your air-lines do get near anything that can cut them or anything hot.
I get about 5 inches of lift from stock height and I get about 3-4 inches of drop.
Another thing to remember is to upgrade to brass fittings and not the plastic ones they wear out. Also you'll need to air gauges one for the front and one for the rear. Another then that is not bad at all to install any suspension shop should be able to install it with no problems. If I think of other stuff I'll post up or if you have anymore questions feel free to ask away.
Old Feb 8, 2004 | 01:45 AM
Guilty's Avatar
Here's the website you want to go to www.aimind.com I would write them an email on what you are looking for exactly. Like you want air cyclinders and lines, valves, tank, gauges and switch box oh yeah and a compressor get yourself a 100% duty cycle 3/4 hp compressor. You'll have to oil it after 24 or 28 hours of use. It's easy to do. Also get yourself a water trap to collect water from entering your tank and lines and cyclinders. But you'll be able to chance out suspension without any problems. The only thing you may have to do is zip tie your lines up and out of the way but other then that it's just like changing sturts.
Old Feb 14, 2004 | 01:22 AM
Guilty's Avatar
No problem Henry if you need anymore help just let me know and I'll help you out anyway I can.
