Abs And Handbrake Lights
Old Nov 29, 2008 | 05:46 AM
badshah's Avatar
Vehicle: 1997 Hyundai Tiburon
What does it mean when my ABS and e-brake lights turn on while driving?
When I turn off the engine and start it again, the lights go off..
ABS still functions as it should do..
Anyone?
Old Nov 30, 2008 | 01:01 PM
Is your brake fluid reservoir full?
Old Nov 30, 2008 | 01:11 PM
badshah's Avatar
It's about 40-50% full
Old Nov 30, 2008 | 02:12 PM
not sure about abs.
far as the handbrake light, i had a similar problem. my e-brake cable was broken since i bought the car and overtime it came loose from the caliper side.
Old Nov 30, 2008 | 02:56 PM
fury's Avatar
^^ it's unlikely that a loose cable would trigger the parking brake light to go on; I had my ds cable broken and loose for a couple of months.
Badshaw, does this happen intermittently or is it everytime you drive? Does it matter at which speed? is it by simpling driving, or braking while driving? need more info
Old Dec 1, 2008 | 04:03 AM
badshah's Avatar
It only happened twice. Last time it was about 3 weeks ago. Handbrake is also good and tight, don't think the prob is there.
Old Dec 1, 2008 | 04:56 AM
QUOTE (Badshah @ Nov 30 2008, 03:11 PM)
It's either full or it's not. Is it between the lines, or is the reservoir 40% full?
Old Dec 1, 2008 | 05:51 AM
badshah's Avatar
The reservoir is about 40% filled between the lines.
Old Dec 1, 2008 | 05:20 PM
archsvile's Avatar
Fill it till the F bet you the light will go away.
Old Jan 22, 2009 | 01:14 AM
badshah's Avatar
It's fixed. It was the plus cable which was a bit loose and thus not making a good connections with the battery. Tightened up a bit and problem solved!
