5 lug conversion
Old Aug 22, 2011 | 11:04 PM
AvanteKing's Avatar
Vehicle: 1998 Elantra
Default 5 lug conversion
I got a 1998 elantra I want rear disc swap with a 5 lug conversion. Whats the best route?
Old Aug 23, 2011 | 12:35 AM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
99 Tiburon Rear Hubs with the disc there plug and play...
Old Aug 23, 2011 | 07:01 AM
SR Tech's Avatar
Vehicle: 2011 Tuscon
99 rear hubs are 4 lug...
I've have yet to successfully see a 5 lugs swaps on RD platforms. Many have claimed they did it and had pictures, but could never tell us exactly how they did it, besides re drilling the hubs which i would never do imo
Old Aug 23, 2011 | 08:54 AM
you need the rear cross memeber from a GK. the fronts are bolt in but the rear linkage is compeltely diffrent.
i have all the spindles you need if your intrested. 100+shipping for everything
Old Aug 23, 2011 | 01:35 PM
BetaRD2's Avatar
Vehicle: Tiburon 2001
the easiest way i think is to get GK front hubs and spindles as well as brake components which MUST be out of a 4 cilinder car so that your elantra axels fit and the front is basically plug and play
for the rear in your case i would convert to 99-01 tib so that you get the rear discs you want and then get a pair of billet 1" adapter spacers that bolt to the wheel studs and have the 5x114 lug pattern
and presto 5 lug with rear disc
Old Aug 23, 2011 | 10:42 PM
^^easier option
but brakes will be the same bolt pattern and size either way. even better option is to do xg bbk in the process
