2017 Santa Fe SE AWD rear air shocks or spring assist
Old Nov 7, 2018 | 01:47 PM
canyon's Avatar
Vehicle: 2017 Hyundai Santa Fe SE AWD
Default 2017 Santa Fe SE AWD rear air shocks or spring assist
I would like the stiffen up the rear suspension with either air shocks or air lift. I seem to bottom out easily on speed bumps, also I want to tow with a 300# tongue weight. I see there is a cushioned filler on the inside of the rear springs preventing an "in spring" airlift. Has anyone found and air shock that may be fitted? I would like to stay away from the in between the coil cushions. Any experience or advice is appreciated.
Thanks.
Old Nov 7, 2018 | 06:56 PM
The thing you are looking for is often called a "helper spring". These are often in the form of a replacement for the bump-stop in the middle of your current spring, though some bolt on other locations.
These are only listed up to 2016 but there may be a suitable similar item for your 2017 https://www.suspensionconnection.com...-air-bags.html
Here is a report of one user's experience: https://www.supersprings.com/topic/2...ndai-santa-fe/ installing this plastic insert that goes into the coils of the spring https://www.supersprings.com/shop/CSS-1145/
Here are a few more "universal" type of things you could consider: https://www.carid.com/universal-help...vehicle=123253
Old Nov 7, 2018 | 08:14 PM
canyon's Avatar
Default Thank you for the response
Thank you very much for your quick response. I agree with the premise of the first fix, that is the most desirable to me, however that design cuts off at 2016. I have a 2017.
The second fix I rejected from an engineering standpoint stated in my original post, that the "between the coil" rubber spacer puts more stress on the remaining coils, and is not at all desirable.
I have researched the third suggestion of CARiD earlier and I saw no products for that year Santa Fe.
It appears there are no air shocks available either. It may be a situation that it is too new a design that the aftermarket has not caught up yet, or not enough vehicles to warrant development of a solution.
Related Topics
Thread
Forum
Replies
Last Post
Hyundai News Bot
Hyundai/KIA RSS Feeds
1
Feb 12, 2016 06:17 AM
Kent
Hyundai Santa Fe Forum
8
Apr 28, 2014 05:22 PM
Hyundai News Bot
1
Nov 28, 2012 07:52 PM
Hyundai News Bot
0
Feb 11, 2009 11:23 PM
REDZMAN
10
Apr 6, 2006 08:20 PM
