**HELP** what is the caliper bolts size?
Old Oct 28, 2004 | 02:14 PM
97supalude's Avatar
Default Re: DIY : Clear Corners
hey i stripped the bolts that screw the calipers on... anyone know what size those are? and its a 2000... btw.. is that rd2? (for future reference)
Old Oct 28, 2004 | 02:23 PM
Default Re: *Exhaust Listings* Currently Available...
yeah, its a rd2.
are you talking about the front or rear calipers?
the fronts use 17mm bolts to hold the caliper to the knuckle, and 14mm bolts to hold the caliper together.
the rears use 14mm bolts to hold the caliper to the knuckle, and 14mm bolts to hold the caliper together.
but if you stripped them , you already know that right? :?
are you looking for specific sizes like length, diameter, and thread size of the bolt?
Old Oct 28, 2004 | 02:27 PM
Default Re: REAR VIEW MIRROR VIBRATION STOPPER
Yup, 2000-2001 = RD2.
Also mang, just as a good refrence, almost ALL of the bolts on the RD's are 10, 14, or 17 MM.
If the socket or wrench isn't tight, change up.
There are a few 12's, and a few 8's that I've found.
Old Oct 28, 2004 | 03:35 PM
supercow's Avatar
Default Re: RD possible 8,000 redline??
QUOTE (REDZMAN)
