Squeaky Clutch In The Wrx
I have a VERY squeaky clutch in my 03 WRX, every time i push it in it squeakes...LOUDLY..the ones i found were all quiet (in the search). it sometimes even squeaks when I go over bumps or dont even have the clutch down... I took a video of this...
http://silentlighting.com/Misc/19sec.avi
there it is. go for it and listen for yourself. I am a mechanical N00b so anything that you say to grease, you're gunna have to tell me where it is lol..but yeah, please help me ditch this sound..its SO loud inside and out.
Sounds like the clutch bushings. You can possibly lube them, if you can get to them, but that will only be a temp fix. Always good to put in new ones when changing a clutch as a precaution against squeaking too.
Hmm, after watching the video I don't think that's what it is. A squeaky bushing should only squeak when you depress the clutch pedal.
Well I dont know what else it would be, im assuming that when im driving the road vibrations are making something rub in there the same when the pedal is depressed.idk.
Vehicle: 2000 hyundai tiburon
try adjusting the clutch linkage. alot of times when you buy a used car the previous owner never adjusted it, which needs to be done periodically since it tend to move alot
