Gas only CR-Z Turbo on the way?
http://www.leftlanenews.com/honda-re...only-cr-z.html
I'm usually not a big fan of Hondas but I really like the body of the CRZ, and without the massively heavy hybrid garbage I bet it's pretty light. Well I, like many, have been b*tching they need to make Gas-turbo variant anyway. Looks like they are planning the Type-R nameplate for it too, which means we can probably expect some additional weight reduction and suspension upgrades. Just speculation, but based on history it looks to be a high possibility. I might actually BUY a Honda, whoda thinket?
Honda’s all-new CR-Z hybrid is intended to blend performance with fuel economy, but a future version of the hatchback may put a greater emphasis on all-out performance.
According to the UK’s Autocar, Honda is readying a gas-only version of the CR-Z. The CR-Z currently comes fitted with a 112 horsepower 1.5L four-cylinder mated to Honda’s integrated hybrid system.
The gas-only version of the CR-Z will reportedly come with a turbocharged 1.6L four-cylinder engine. Two versions of the mill are said to be in the works – a base model with 160 horsepower and an up-level 200 horsepower variant. The latter will likely be branded as the CR-Z Type R, although the Si nameplate could be used for the U.S. version.
Honda has yet to confirm if such a plan is in place, but the Japanese automaker did display a factory-backed turbocharged version of the current CR-Z at the 2010 SEMA Show in Las Vegas. If the latest reports are to be believed, the gas-only version of the CR-Z should be unveiled by the end of next year.
They needed to do something to compete against the Veloster. Assuming that Hyundai fixes the rear styling enough that anyone would even consider buying one.
