Belt Squeel
Old Aug 25, 2005 | 08:16 AM
Sparticus's Avatar
Vehicle: 97 Tiburon
where do i start trouble shooting to make it stop?
my girlfriend has a 98 Neon and when the car first starts up, the belts squeel like crazy. sometimes its for a while, sometimes its for a quick second or two... and other times it doesn't at all.
should i be focused on the belt? the tensioner? or a pulley... or all of the above?
thanks
Old Aug 25, 2005 | 08:59 AM
SpeedRacer's Avatar
All of the above. Chances are she just needs a new belt. Shouldn't be hard to figure out which one by sticking your head under the hood and inspecting/listening to them all. Once you find the offending belt, pull it off and spin any pulleys/tensioners/idlers related to it and make sure they spin freely and quietly.
I'd recommend replacing all the belts at once, just makes life easier in the long run.
Old Aug 25, 2005 | 01:58 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
to check what belt is squeeling, you can spray WD40 on the pulleys (when engine is running). And see when the belt stop squeeling.
Cehck if that belt has correct tension, it may be loose.
Old Aug 25, 2005 | 02:14 PM
fonseca's Avatar
Quick fix is a bar of soap on the inside of the running belt, or a shot of belt quiet spray.
I'm about to replace all of mine at once.
Old Aug 25, 2005 | 02:42 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
although i know i could easily change it... i can't primarily because my left arm is in a cast.
thanks for the ideas
