Extra Injector And Other Atelier Hp Stuff
so this magic box only forces the ecu into open loop DURING boost? how does it do this?
(plz don't say magic wink1.gif ).
1.) Cut a holw in that box.
2.) Put your SMT-6 in that box
It's my **** in a box.
sorry. I had to.
sorry. I had to.
Dennist,
If you can drill and tap 4 holes in the bottom for the Fogger nozzles i can take care of the rest that isn't a problem or an issue. JUst if it can be done let me know and i will take one, also i need paypal info so i can send you money for this.
NightShark,
you're right complete kit includes everything needed exept the injectors,wiring and fuel controler
we could say that it includes the "mechanical parts"
yes you can use stock injectors,we made them to accept the most popular injectors (stock, beta2,ford bosh style,gm bosh style and delphi style) basicly all injectors that uses 15-16mm o'rings
for the air ram, no problem to use it,the only trick is to mount the ISC under the intake manifold instead of behind it,fill up your front and rear mount with urethane and it will work nicely
Patreezy,
the turbo box is controled by the smt-6 orange wire (switch) that saved us the problem and cost of mounting a map sensor inside the box
so this makes it adjustable in a lot of ways (engine temp, rpm, boost, and throttle)
Zippy1,
cyl 2-3 and 4 are going to be easy to set up, the #1 cylinder will be the one with "problems" ,if you have AC then you will need to remove the NOS fittings from the nozzle and make and install 90° ones instead
send me an e-mail at atelierhp "at" hotmail.com with your adress and i'll get you an exact quote for shipping
Patreezy,
Zippy1,
extra injectors spacers :
1-----west downpaiement received
2-----Ciric downpaiement received
3-----Turbulence downpaiement received
4-----Zippy
5
throttle bodies:
1-----l'homme
2-----Jimbo downpaiementreceived (b1c)
3-----Hugo
4-----Azhur (b1)
5-----optimoprime
6-----rallyman downpaiement received (b1c)
Turbo box:
1-----tanc
2-----turbulence downpaiement received
3-----Rbak100
4-----West downpaiement received
5
here's what i have for now i shouldn't be forgetting anyone ;-)
BTW for the TB B1C means beta1 with cruise, B1 means beta 1 no cruise....
4-----Zippy
5
throttle bodies:
1-----l'homme
3-----Hugo
4-----Azhur (b1)
5-----optimoprime
Turbo box:
1-----tanc
3-----Rbak100
5
Dude im in for the turbo box and 58mm throttle body with cruise control, just send me pm with your paypal details. My postal code is WV14 9YW in the UK for an exact shipping quote. Cheers
