Throwdown Performance
Sponsor:   Throwdown Performance
Offering all types of performance and suspension products for different Hyundai's and other imports!
http://www.throwdownperformance.com
KSPORT AirRide Suspension/Big Brake Kits/Coilovers @ THROWDOWN!!!!!!
Old Apr 19, 2011 | 05:23 AM
Throwdown's Avatar
Vehicle: 04 Tiburon GT
Default KSPORT AirRide Suspension/Big Brake Kits/Coilovers @ THROWDOWN!!!!!!
Been searching for AirRide Suspension or a Big Brake Kit for your Hyundai? Look no further! After numerous requests in 2010 we are happy to offer the updated AirRide kits available out to the forum! 4 Different Models to Now Available for 2011!
All Ksport Airtech Systems feature:
- High quality air bags, proven to handle the stress and abuse of daily driving as well as drift circuit use.
- Near infinite adjustability thanks to the adjustable lower mount, 36 levels of damping adjustment, and the unmatched height adjustability (0-200mm) of air suspension.
- Easy bolt-on installation. No modifications to OEM shock absorbers, or OEM top mounts. Vehicle may need to be modified for air line routing.
- All Ksport Airtech Systems use VIAIR compressors, and can be raised from the lowest setting to max height in as little as 2 seconds.*
- All Hoses, wiring, and installation manuals are included.
* Airtech Pro and Pro Plus will raise your vehicle in 2-5 seconds. Basic and Deluxe require 4-7 seconds.
Product may vary depending on vehicle
All other available parts both listed by brand and by model!!!
KSport Big Brake Kits!
Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
Most applications utilize the 2-piece floating disc assembly, which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
*Product may vary depending on vehicle
====>>> ALL HYUNDAI BIG BRAKE KITS CAN BE FOUND HERE!!!
ALL OTHER BBK'S LISTED BOTH BY MODEL AND BY BRAND!!!
KSport Kontrol Pro, GT Pro and Version RR Coilover Kits!
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Where available, camber canbe adjusted via the Pillow-ball Top Mounts, which means no additional "Camber Kits" are needed.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer damping adjustments, and requires more expensive design process. Aeration and cavitation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
1. 36 levels of adjustable damping
2. Made from high quality 6061 aluminum with T6 for increased hardness
3. Compression/Rebound adjustable
4. Adjustable spring perch for height adjustment
5. Adjustable body allowing maximum suspension travel
6. Pillowball top mount with adjustable camber (not available for some models)
7. Monotube high pressure design reduces oil leakage
8. Electroplated body for protection from corrosion and rust
9. One year limited warranty
Ksport GT Pro Damper System provides the ultimate in suspension technology featuring an inverted monotube design, 36 levels of adjustable damping, adjustable spring perch, adjustable body and pillow-ball mounts. With the gas/oil chamber farther away from the knuckle and braking system reducing heat transfer. This design also reduces under-sprung weight, which improves handling and responsiveness.
36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer damping adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
Key Features:
1. Inverted steel shock absorber for durability
2. Lower center of gravity and higher chassis rigidity
3. Designed to reduce friction for cooler shock oil temperature
4. Inverted design like vehicles in WRC and all JGTC cars
5. 36-way adjustable damping
6. Made from high quality 6061 Aluminum with T6 for increased hardness
7. Compression/Rebound adjustable
8. Adjustable spring perch for height adjustment, Adjustable body allowing maximum suspension travel
9. Pillow Ball Top Mount w/ adjustable camber (not available for some models)
10. Monotube High Pressure Design reduces oil leakage
11. Electroplated body for protection from corrosion and rust
12. One Year Limited Warranty
Ksport Version RR Damper System is built specifically for road racing only. Aggressive rates and valving are chosen for maximum handling and performance with acute reaction and responsiveness. Integrated with 36 levels of damping adjustment, simultaneous compression and rebound adjustment, lightweight aluminum mounts, and pillow ball upper mounts on some applications. (Race use only.)
36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustment via the Pillow-ball Mount is available for certain aplications, allowing camber adjustment without an additional "Camber Kit."
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer damping adjustments, and requires a more expensive design process. Aeration and cavitation are a lot less common in a Monotube design, which results in a better ride.
Key Features:
1. Aggressive valving and spring rates
2. Reinforced internals
3. Race applications only
4. 36-way adjustable damping
5. Made from high quality 6061 Aluminum with T6 for increased hardness
6. Compression/Rebound adjustable
7. Adjustable spring perch for height adjustment
8. Adjustable body allowing maximum suspension travel
9. Pillow ball top mount w/ adjustable camber (not available for some models)
12. One year limited warranty
Please don't hesitate to email, PM or message us on AIM/Facebook with any questions you may have!
Old Sep 22, 2011 | 02:44 PM
2010_Genni's Avatar
Vehicle: 2010 Genesis
Has anyone ever used KSport, or can tell me if they're worth the price? Are they better than Megan Racing or BC Racing? I've never heard of them, but want to buy coilovers ASAP.
Old Sep 22, 2011 | 02:48 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Ksport Pro's, I have had them for about 2 years and there just amazing, once you set them up it is great stuff, Never ever have i had one issue with them!
Old Sep 22, 2011 | 02:50 PM
A lot of people run BC Racing in the Genesis community. Nothing against KSport, I have no personal experience with them, but BC seem to be reliable also.
Old Sep 22, 2011 | 11:14 PM
ksports been around the hyundai scene for awhile. never heard a bad word about them, they are just lil pricey because its higher end parts.
Old Sep 23, 2011 | 08:15 AM
Ksports would not be my first choice, but they are adequate. Comparable to any other non premium coilover manufacturer. The older versions had struts that were absolute crap, but any current products have gone up in quality. If you want to use them for racing you can even have them put your struts on a shock dyno so that you can match them to one another more easily.
Old Nov 5, 2011 | 11:35 AM
Throwdown's Avatar
Nothing wrong with either... we have been selling BC's for years as well!
And thanks for the review
Old Apr 18, 2012 | 06:01 PM
Throwdown's Avatar
Thanks for the orders!
