JLB Motorsports
Sponsor:  JLB Motorsports
JLB Motorsports, brand-name rims, including Rota, Momo, Espelir, Advan, Rays, Falken,
Drag and Konig for your Hyundai!
http://www.jlbmotorsports.com/
Rota Wheels
Old Sep 29, 2008 | 03:35 PM
JLB Motorsports's Avatar
Here is the list of what Rota has available for the 97-01 Tiburon. Please copy and paste the specs from the list of the wheels you would like to purchase or have questions about and PM or email us at (info@jlbmotorsports.com).
For pictures, you can look at our site :
http://www.jlbmotorsports.com/rims/rota-list.html
AUTO-X 1670 40 8/114.3 73 RCTBLUE
AUTO-X 1670 40 8/114.3 73 RCTRED
AUTO-X 1670 40 8X100/114.3 73 FBCRED
AUTO-X 1670 40 8X100/114.3 73 RPINK
AUTO-X 1670 40 8X100/114.3 73 SGCTRED
AUTO-X 1670 40 8X100/114.3 73 WCTRED
BOOST 1775 45 4X114.3 73 FBRL
CIRCUIT 10 1670 45 4X114.3 73 GM
CIRCUIT 10 1775 45 4X114.3 73 BRZ
CIRCUIT 8 1670 40 8X100/114.3 73 BRZ
CIRCUIT 8 1670 40 8X100/114.3 73 FBLK
CIRCUIT 8 1670 40 8X100/114.3 73 FRSB
CIRCUIT 8 1670 40 8X100/114.3 73 GM
CIRCUIT 8 1670 40 8X100/114.3 73 PS
CIRCUIT 8 1670 40 8X100/114.3 73 RBLK
CIRCUIT 8 1670 40 8X100/114.3 73 RGM
CIRCUIT 8 1670 40 8X100/114.3 73 WCTRED
FIGHTER 1565 40 8X100/114.3 73 GOLD
FLIGHT 1565 40 8X100/114.3 73 RGM
GT3 1570 40 4X114.3 73 RPINK
GT3 1670 40 4X114.3 73 RS
JMAG 1670 40 4X114.3 73 RGOLD
TORQUE 1775 45 4X114.3 73 SG
TRACK R2 1670 40 4X114.3 73 RSG
Contact information :
JLB Motorsports
505 North Smith Avenue
Suite 107
Corona, CA 92880
By telephone:
Monday to Saturday from 10 AM to 6 PM : (951) 734-4411
By e-mail : info@jlbmotorsports.com
By AIM : JLBSupport or JLB Motorsports
Old Sep 29, 2008 | 04:22 PM
Out of curiosity, I know the '06 Elantra is the same bolt pattern, but what about the bore? Is it 73mm also?
Are rings needed with the 73mm bore rims (on the Tib or Elantra)? I ask because my Slipstreams fit my '01 Tib perfectly without rings and I don't know what size bore they were.
Thanks.
EDIT: I also own a 350Z and was looking at the P45's. Just wanted to point out a small problem with your site/shopping cart. The P45F's and P45R's are usually bought in sets of 2, since the F's are for the front and the R's are for the rear. When you add them to the cart, it adds 4 and there's no way to change it to 2. Maybe set it up so when you add these to the cart, it adds 2 instead of 4. Just a suggestion.
Old Sep 29, 2008 | 05:04 PM
Tibbychick's Avatar
^JLB actually recently helped me source a replacement 16" slipstream for my tib, and they had very few left in our bolt pattern. I had to settle for flat black because Rota just doesn't have stock on our size anymore.
I have hubcentric rings with wheel spacers and my slipstreams are 73mm. It's a snug fit.
Old Sep 29, 2008 | 05:12 PM
i8acobra,
I definitely didn't forget about the Slipstreams cool.gif . They are simply out of stock right now at Rota. I listed the current stock of 4x114.3 wheels so you guys would know what is available right now. Rota makes the 4x114.3 Slipstreams but they are currently all out of stock.
We've sold many sets of P45, a lot of people use them in an symmetrical setup on their vehicle. The people who want a staggered set can contact us as there are usually problems with Rota not having either the front or rears in stock (sometimes neither are available).
Tibbychick,
Thanks, I was the one who talked to you via email. It is unfortunate that Rota doesn't have more wheels available for the Slipstreams, and I remember that your particular replacement took 2 tries to get in because Rota couldn't find it on the first attempt.
Old Sep 29, 2008 | 05:26 PM
Ive never actually heard of bore when ordering wheels. Can this be explained a little? Every wheel Ive bought has just been on size, bolt pattern, and offset and they always work?
Old Sep 29, 2008 | 06:18 PM
The 97-01 Tiburon uses a 67.1 mm hub bore. The hub bore is the size of the hub on your car. Wheels are usually made in the "universal" 73 mm hub size. So in most cases you can fit the wheel on your car as long as it has the 73 mm hub size. However, the wheel will not be hub centric. The wheels aren't required to be hub centric but if you want it to be hub centric you can purchase hub centric rings. We sell HCRs for $15 for a set of 4 polycarbonate rings or $20 for the metal version.
Old Sep 29, 2008 | 07:14 PM
Tibbychick's Avatar
Do you know if Rota will be stocking the slipstreams in 4x114.3 in the future, or are they phasing that out since it's such an off size?
Old Sep 29, 2008 | 08:12 PM
So, I guess I must've had the 67.1mm bore then. Sucks they don't have 'em anymore. I was wanting a set in Gunmetal or Gold for my '06 Elantra. On that note... Is the '06 Elantra 67.1mm also? I'd prefer to have a snug fit without needing rings.
EDIT: NVM... looks like Rota doesn't have ANY 16" or 17" 4x114.3 rims with a 67.1mm bore. Guess I'm stuck with 73mm with rings.
<div class='quotetop'>QUOTE (JLB Motorsports @ Sep 29 2008, 04:12 PM) <{POST_SNAPBACK}></div><div class='quotemain'>i8acobra,
We've been around long enough to know whats going on cool.gif</div>
Really? I've been into the 350Z scene for 2 years and I've never seen anyone run F's or R's all around. I understand you're in the business, so you see more than me, but I've never even heard of doing that. The offsets are all wrong. Either way, it was just a suggestion.
Old Sep 29, 2008 | 08:36 PM
CudaJoe's Avatar
Do you happen to know the weight of these rims? I wanna grab some rims but I don't wanna have heavier rims than the stock ones which I think are around 18Ibs. I thinking about grabing 16" rims hopefully around 16.5Ibs each. And how does your wheel+tire deal work? Is there a discount for buying them packaged together (such as mounting and balancing free) or are they just a combination of the prices?
Also someone explain the offset # to me? Is it how far the rim extends outwards from the car compared to stock?
Old Oct 1, 2008 | 05:58 PM
Almost all Hyundai models are 67.1 except for the Accent as far as I know. Hub centric rings aren't a bad thing at all considering that it is the same as having the wheel hub centric.
For a wheel and tire quote please contact me via PM on this forum, thank you!
