Atelier HP
Sponsor:   Atelier HP
If you can think about it, they can make it for your Hyundai!
http://www.atelierhp.com/ = French (Canada)
http://www.atelierhp.com = English
Extra Injector And Other Atelier Hp Stuff
Old Mar 13, 2007 | 11:37 PM
Denisst99's Avatar
Last year GB was a succes so i taught i'd pass the deal along this year also,
we've added a few items that gained popularity
paiements are made to Atelier HP directly,
prices don't included shipping and core charges (if applicable)
all items are in stock, and ready to ship as soon has we reveive 5 accounts or paiment for the specific item
prices are good until May 31
i'll add more items to the list later this week<ul>extra injectors spacer kit[*]complete kit
regular price 650$can GB price 515$can around 435$us[*]partial kit
regular price 550$can GB price 435$can around 370$us[/list]<ul>[*]turbo box
regular price 70$can GB price 60$can around 50$us[/list]<ul>[*]oversized throttle bodies (58mm) beta 1 and beta 2 (core charge will de applied and refunded once we receive the stock TB)
regular price 175$can GB price125$can around 105$us[/list]<ul>[*]accent rear disc brackets to adapt tiburon rear disc brakes to X3 LC and LC2 cars,brackets only,no bolts,no handbrake adaptors,no instructions,please specify car when ordering
GB price 115$can around 95$us[/list]
Old Mar 13, 2007 | 11:56 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Denis, can you list everything that is included in the full 2nd rail also a list of the partial kit. Take some pictures as well if you can.
You should add your modified MAF to the list.
Old Mar 13, 2007 | 11:59 PM
I've been waiting on some pricing for this lightweight BBK for almost 6 months. Can you get it?
Old Mar 14, 2007 | 12:10 AM
Denisst99's Avatar
here's some pics and a quick description of each item
complete extra injector spacer kit includes the following:<ul>[*]the spacer itself[*]fuel rail made from extrusion specialy made for fuel rails[*]fuel rail mounting lug for long and short injectors[*]9 longer intake manifold studs[*]2 intake gaskets[*]high pressure fuel injection Gates or Dayco rubber fuel hose[*]required high pressure hose clamps[*]required fitting and a 5/16" "T" fitting for hooking it up to your existing fuel hose[*]intake manifold bracket spacers[*]cruise control relocating bracket[*]required bolts,nuts and washers[*]zip ties[*]instructions[/list]basicly, everything is included for a trouble free installation with common hand tools
Partial (intermediate) kit includes the following:<ul>[*]the spacer itself[*]fuel rail made from extrusion specialy made for fuel rails[*]fuel rail mounting lug for long and short injectors[*]9 longer intake manifold studs[/list]
turbo box
sorry no picture,
it's a little black electronic box wich used in conjuction with the SMT-6 forces the ECU into open loop
this makes tuning MUCH easier,and gives you better fuel control
wiring is quite simple only 5 wires to hook up
here's a picture of two oversized beta throttle bodies
TB is disassembled and parts are checked
each part is glassbeaded to get a like new finish
TB housing is then bored out to 58mm
a new butterfly is made of of T6 aluminium
steel parts are painted black
cooling tube are removed for the beta1 TB's
here's a picture of our accent rear disc brake brackets
this lets you install the tiburon rear disc brake on 1995 and up accent with only common hand tools,no machine work to do,no grinding
Tanc, i forgot about hose
but i should be adding more cool stuff later this week ;-)
Redz, i was convinced that pricing has been sent to you a while ago,i'll get that your way tomorrow
Old Mar 14, 2007 | 07:27 PM
Zippy1's Avatar
I have been waiting for this GB.... as soon as i get my tax return..count me in
Old Mar 14, 2007 | 07:51 PM
supercow's Avatar
interesting, can you give us a bit more on the black box? how is it going to change tuning? will it be useful on a single rail setup?
Old Mar 14, 2007 | 10:49 PM
Denisst99's Avatar
Supercow,
to be honest,i've never tried it myself on a single rail system,
but it might be worth a shoto to try it,i'd say it might help you tune it a bit
what it basicly do is quite simple
force the ecu into open loop under boost this has for effect to let you run the A/F you want underboost (partial and full load) without the ECU trying to figth back your settings
Redz,
i've came up with 895can$ but i'll have to comfirm,i was searching for the price and had to come back home in a hurry...
Old Mar 16, 2007 | 03:43 PM
Zippy1's Avatar
Denisst,
What was the word on if you could drill and tap these for NOS Fogger nozzles?
Old Mar 16, 2007 | 06:56 PM
Jay-M's Avatar
Vehicle: 01 Tiburon
<div class='quotetop'>QUOTE (Supercow @ Mar 14 2007, 06:51 PM) <{POST_SNAPBACK}></div><div class='quotemain'>interesting, can you give us a bit more on the black box? how is it going to change tuning? will it be useful on a single rail setup?
I know jay's a big fan of it. wink1.gif</div>
im positive that it'll be very useful with the single rail/larger injectors setup!!! fing02.gif (just as long as you are using the SMT-6. You have to have the SMT-6 for it to work. It may very well be a piggyback within a piggyback lol.gif wink1.gif )
yes, im a big fan of it because it works! and not to mention that denis is a great guy to deal with fing02.gif
Old Mar 16, 2007 | 07:33 PM
tanc's Avatar
So denis, I talked to you on msn a while ago about the magic box. When are you taking orders? I'd like my magic box in the color pink cool.gif
