Hyundai Aftermarket
-   Wanted (https://www.hyundaiaftermarket.org/forum/wanted-18/)
-   -   Wtb: O2 Sensor Plug 1997 Only (https://www.hyundaiaftermarket.org/forum/wanted-18/wtb-o2-sensor-plug-1997-only-48812/)
HyundaiKitCoupe Jul 16, 2008 10:22 AM
I need:
1. Front O2 socket from engine harness from a 1997.
Simple as that.
HyundaiKitCoupe Jul 18, 2008 04:35 PM
bbbbbumpety before i go to the yeard
HyundaiKitCoupe Jul 20, 2008 03:30 PM
well, i'm at my last resort. if anyone can help i'd be grateful. i found a 1999 but the plugs on it are the newer kind.
https://i53.photobucket.com/albums/g...ye355/wrk1.jpg
https://i53.photobucket.com/albums/g...ye355/wrk2.jpg
https://i53.photobucket.com/albums/g...ye355/wrk3.jpg
poor things. lot of good parts on them though. frames and engines looked good too.
Ericy321 Jul 20, 2008 05:09 PM
Got a pic of what you need? Its a 4-wire? Just post a pic since almost all of us have the "newer style"
Why not get a new style plug and a new style O2 sensor? I guess it would cost a little more but you could probably even get a used O2. Just a thought.
HyundaiKitCoupe Jul 20, 2008 05:23 PM
that's the hard part, they changed the 4-pin wiring order and female-male connector plugs in all models in 1998+. i've tried my best to get the right wiring order but nothing works, so i'm converting everything to how it was before and i don't want to change any order so i can be sure.i cut the socket out accidently years ago. two other folks have a similar problem.
the socket is like the RD2 one but with a hollow center. the pins should be located in the socket rather than the other way around.
thanks though...
Ericy321 Jul 20, 2008 05:25 PM
Damn. That sounds wierd. Sorry I couldnt help more.
So basically the plug is reversed then right?
HyundaiKitCoupe Jul 20, 2008 05:29 PM
correct! i checked all of the elantras, but it's the same 4-pin RD2 plug/socket.
