Wtb: Crank Sensor
Old Feb 3, 2008 | 02:19 PM
JonGTR's Avatar
I need a crank sensor.
Make sure that it has the o-ring style plug with the 10mm bolt on the bottom, and not on the right side of the sensor.
Old Feb 4, 2008 | 07:01 AM
netsniper's Avatar
Vehicle: uhm..... N/A
I have one off of a 1.8l beta motor. Came off of a motor with 38k on the clock. If it will work whats it worth to you. I dont have a reason to keep it other than monitary value
Old Feb 5, 2008 | 12:09 PM
JonGTR's Avatar
Are you sure it's the correct sensor as I described? I've looked at a lot of betas in the junkyard and most of them were older models, 1.8L's, and had the 10mm bolt on the right side of the sensor.
If your mounting hole is on the bottom, and has the o-ring, then I can pay you $15 shipped for it. you can throw it in the cheap USPS flat rate envelope or whatever.
Old Feb 7, 2008 | 07:00 AM
JonGTR's Avatar
N/M, found one on ebay for $15 shipped.
