Need a drivers side window assembly and passenger side window switch
I need two different things. I need the passenger side power window switch (if it works).
I also need the entire driver side window assembly. The cable got spun up in the pulley and I had to brake the cable. So I need the main cable pulley that bolts to the window motor, all the cables, all the window slides and brackets, etc. Everything but the window and motor for the drivers side. Let me know if you have it all. Thanks!
Vehicle: 1999 hyundai tiburon turbo/ 2001 Tiburon(sold)
I have both pieces you need, the drivers side door assembly is 1 full unit including the motor. can email you pics if needed. I will sell you the switch and door assembly for $40 + shipping . give me your zip if interested and can get you a quote
ps anything else you need. have a lot from a 2001 part out..
