Turbo Upgrades?
Hey I was just looking at your site and noticed the ONLY upgrade is for an IC. I was wondering are we able to purchase other parts? like bigger turbo, or different manifold? Also, are we able to JUST buy certain parts of this kit? for example...say i want everything BUT the turbo and manifold, are we able to do that? What does your stage 1 kit put out horsepower/torque wise? Are we able to get different color couplers? Could you maybe Sticky the specs of the turbo kits? like size of IC, down pipe, IC piping, etc...
Thanks in advance
Matt
Thanks in advance
Matt
That is the only upgrade for now. We've recently switched over to a supplier of Garrett turbos so we'll have access to Garretts full line of Turbochargers. The Stage 1 intercooled kit now comes with a Garrett T28 Turbo instead of the Mitsubishi 15T.
As our partner ship with KSpec grows we hope to be able to offer some of thier manifolds as upgrade items to our kits.
We use Hose Techniques as our coupler supplier so any color they offer can be included in the kits. By default we use red.
All piping is powder coated black unless the optional polished is specified. I had the stock kit running at 12psi on my BetaII and pumped out 226WHP/220WTQ. BetaI numbers should be really similar with the new tune we have.
QUOTE (homey14h @ Sep 7 2006, 11:17 AM)
Also, are we able to JUST buy certain parts of this kit? for example...say i want everything BUT the turbo and manifold, are we able to do that? Could you maybe Sticky the specs of the turbo kits? like size of IC, down pipe, IC piping, etc...
+1^^
If more options are made later I will seriously consider this option in about a year. I may just go completly custom with a local performance guy too. Allspeed Performance. His shop will be featured on some cable shows later on this year.
dm--can you answer this
Again I'm sorry for the late reply.
We can't really offer the kit components separately because they are designed to work together. For example due to the manifold placement of the turbo the downpipe has a very specific design. You woudn't be able to use our downpipe with a different manifold. Same holds true with the charge pipes. The are designed for the specific intercooler we use and won't work out of box with a different intercooler, unless its of the same exact dimensions.
With that said there is always exceptions. We've sold manifolds to people making a custom downpipe and have sold downpipes to people making a custom manifold. Everything has a price but its by far the best deal to buy them as a whole kit.
Here's an example of some prices we've sold components for in the past:
Cast Turbo Manifold = 450 USD
Cast/Welded 2.5" Downpipe = 300 USD
T28 Turbocharger = 550 USD
Intercooler with Piping/Connectors = 750 USD
15psi Tuned Unichip with Subinjector Pipe Assembly = 800 USD
Braided Stainless Oil & Water Feed/Drain Lines = 200 USD
