Vendor's Booth: General
Sfr 1.6/2.0 Turbo Package 2
Old Apr 11, 2007 | 11:19 AM
I also forgot to post this when it went up. I'm slacking.
http://www.kdmstuff.com/shop/step1.php?number=1044
- SFR's base bolt-on turbo kit Stage2 and Stage2-Super
- Suitable applications for people who's looking for more power and better torque band adavanced from our Stage 1 Kits
Stage 2 kit will produce about
Manual tranny (240-250whp,34kg.m(246lb.ft)-36kg.m(260lb.ft))and Auto tranny (210-225whp,30kg.m(217lb.ft)-32kg.m(231lb.ft)) for 2.0
Manual tranny (200whp-210whp,26kg.m(188lb.ft)-28kg.m(203lb.ft)) and Auto tranny (180whp-195whp,24kg.m(173lb.ft)-26kg.m(188lb.ft)) for 1.6 engines @ internal waste set of 0.8bar-1bar(11.8psi-14.5psi)depends on the octane rate and other modifications
- T3 Super60 turbo has an internal wastegate and you will be able to push 0.8bar-1bar
- Our kit will not work with 2005+ CVVT Auto tranny Cerato
- Dyno proven and tested by SFR
- Our kit is also designed for easy and less cost upgrade in the future when you are looking for more power
Stage 2 kit components
- Garrett T3 60 turbo (Fast spool up time,not much lag,good torque)
- Spark plugs NGK 9
- 2.5 bar MAP sensor
- 630cc Injectors
- Turbo 8.5:1 Low compression gasket
- Blow Off valve
- Turbo piping set
- All necessary silicone hoses, vacumme hoses and clamps
- Intercooler
- Inline hose (Head->Turbo) and Outline hose (Turbo->Oilpan)
- Turbo Manifold
- Turbo diffusor and downpipe
- Clutch metal cover and pressure plate (opitonal for Manual tranny)
- ECU convertor and crank degress sensor (1.6 Alpha engine only)
- SFR remapped ECU
- Tranny oil cooler(Auto tranny only)
Stage 2-Super kit will produce about
Manual tranny (290-300whp,38kg.m(274lb.ft)-40kg.m(289lb.ft))and Auto tranny (265-275whp,32kg.m(231lb.ft)-34kg.m(246lb.ft)) for 2.0
Manual tranny (240whp-250whp,32kg.m(231lb.ft)-34kg.m(245lb.ft)) and Auto tranny (215whp-225whp,26kg.m(188lb.ft)-28kg.m(202lb.ft)) for 1.6 engines @ external wastegate and boost controller set of 1.2bar(11-12psi)depends on the octane rate and other modifications
Stage 2-Super kit optional components
- External wastegate type Manifold
- Fuel Return line setup
- Manual boost controller
- Tial 38mm 1Bar(14.7psi)set Wastegate
- Walbro 255 fuel pump
- SFR turbo kit is only consist of proven and high quality parts
- Every parts are brand new
- We will allow customers to include or exclude some of parts and work with prices
- Our kit is bolt-on, so anybody with right tools and knowledge can install it (However, we still recommend you to have an expert to install the kit)
- Only few modifications are needed to install the whole kit (welding a connector for oil line and removing the coolant resorvoir)
- Our kit is designed for Tiburons and used by many shops in Korea so fitment/quality is garanteed!
- Our turbo kits are not intended for street use, so use it at your own risk
- 3 inch piping for exhaust is recommened to have maxium power output and better exhaust flow
- We will also include installation guide and tips upon request
- Our kit only used the best quality products, so prices could be slightly higher. However, you will run into less trouble and get better performance output
- Our kit contains of everything that you need to complete the turbo set up including powertrain upgrade (Stock clutch will not be able to handle the power for manual tranny cars.. You will run into problems and cost you more money in the future, so changing a clutch set is recommended)
- Corecharge for ECU is needed if you want to keep your stock ECU. If you want to send your ECU to us, please send it to our address shown on the bottom
- Shipped by Korea post regular mail with tracking #
Old Apr 11, 2007 | 10:42 PM
Tiburonmoo's Avatar
Vehicle: 2000 Tiburon
Let them know that the kit is not listed in our(Tiburon 96-01) section. The only one in there are "starter" packages. That's a bit pricey though.
