Hyundai Aftermarket
-   Vendor's Booth: General (https://www.hyundaiaftermarket.org/forum/vendors-booth-general-34/)
-   -   Remote Starts - Alarms - Keyless Units (https://www.hyundaiaftermarket.org/forum/vendors-booth-general-34/remote-starts-alarms-keyless-units-15057/)
kingpinelectronics Jun 30, 2009 11:45 PM
http://www.dragondistributing.com/pi.../al2000edp.jpg
<span style="font-size:36pt;line-height:100%">Excalibur Deluxe 2-Way Remote Start Alarm System</span>
This is same alarm w/ remote start that I run on my car.
<span style="font-size:24pt;line-height:100%">$149 <u>Shipped</u></span>
Features 7 onboard relays
4 Dedicated remote starting relays
Data port for IntelliKit plug-in bypass kits and databus modules
Siren and horn outputs
Positive and negative flashing light outputs
Built-in backup battery capability
2 additional remote channel outputs
On-demand low voltage starting programmable features
<span style="font-size:18pt;line-height:100%"><u>Manual Transmission compatible</span> (will only start once after vehicle exit)</u>
For the install you will need to be able to test +/- connections. I will provide the wiring diagram for your vehicle, but due to the nature of the install it is expected that you have a good understanding of wiring OR plan on having it professionally installed. If you are unsure of the install you can buy cards (InstallerNet) from Amazon.com that allow you to schedule the install locally!
Send Paypal with the model # to jared@kingpinelectronics.com
I have several other models to list, but it's late! If you need something let me know! I'm more then happy to answer any questions you may have!
