Products List
ok..im posting up a products list for the tibs based on the CURRENT parts list from BSE....this might change as the compatible parts list changes which will also add to the parts list for the tib
http://bseparts.com/pdf/parts_list.pdf
SPRINGS
Tiburon 09/1996-2001 1.2" DROP FRONT/REAR
SPRING / DAMPENER KITS
Tiburon 09/1996-2001 1.2" DROP FRONT/REAR 4 CYL
SWAY BAR KITS
Tiburon 09/1996-2001 INCLUDES HARDWARE 20MM FRONT 16MM REAR 4 CYL
SWAY BAR / DAMPENERS / SPRING KITS
Tiburon 09/1996-2001 INCLUDES HDWR 20MM FRT 16MM RR 4 CYL 1.1"
DAMPENERS
Tiburon 09/1996-2001 4 CYL
STRUT TOWER BRACE
Tiburon 2000-2001 RD2 FRONT
QUICK SHIFTER
Tiburon 1997-2001 5spd
ALUMINUM FLYWHEEL
Tiburon / Elantra 96-7/99 41mm CRANK 2.0L 4cyl
Tiburon / Elantra 7/99-2005 35mm CRANK 2.0L 4cyl
STEEL INSERT
Tiburon all above FLYWHEEL STEEL INSERT REPLACEMENT
TURBO SYSTEMS
Tiburon NON VVT STAGE I, APROX 42% POWER GAIN, 2.0L NON VVT
Tiburon NON VVT STAGE II APROX 200HP@WHEELS 2.0L NON VVT
CAM GEARS
ALL 1.8L & 2.0L ENGINE CLEAR
ALL 1.8L & 2.0L ENGINE RED
ALL 1.8L & 2.0L ENGINE BLUE
COLD AIR INTAKE
Tiburon 1997-2002 4cyl
CRUISE CONTROL
Tiburon 1997-2005 ELECTRONIC CRUISE CONTROL & CRUISE LEVER
RADIATOR CAP COVER
ALL MODELS ALL YEARS T6 ALUMINUM RADIATOR CAP COVER
BACK-UP SENSOR
ALL MODELS ALL YEARS REAR BUMPER BACK-UP SENSOR
SEAT HEATER
ALL UNIVERSAL FITS ALL MODELS
SPRINGS
SWAY BAR KITS
DAMPENERS
STRUT TOWER BRACE
QUICK SHIFTER
ALUMINUM FLYWHEEL
STEEL INSERT
TURBO SYSTEMS
CAM GEARS
COLD AIR INTAKE
CRUISE CONTROL
RADIATOR CAP COVER
BACK-UP SENSOR
SEAT HEATER
Seat heaters sound nice.. seeing that it'll soon be cold and brisk outside.
What happened to the ECU?
Very curious about how those work. I'd assume they'd work similar to the 1.8 ECU. Need more info!
well...if the elantra ECU works with the rd tibs..then maybe you should go to the parts list..copy what works on the rd's and post it in the cross-compatibility list...that way the rd can be listed for a super chip
Yup. The 1996-2000 Elantra uses the same ECU as the RD's. It's the SAME! So I will go thru the listing some time this week and put down what needs to be updated.
