SPRINGS
Tiburon 09/1996-2001 1.2" DROP FRONT/REAR $239 SPRING / DAMPENER KITS Tiburon 09/1996-2001 1.2" DROP FRONT/REAR 4 CYL $669 SWAY BAR KITS Tiburon 09/1996-2001 INCLUDES HARDWARE 20MM FRONT 16MM REAR 4 CYL $402 SWAY BAR / DAMPENERS / SPRING KITS Tiburon 09/1996-2001 INCLUDES HDWR 20MM FRT 16MM RR 4 CYL 1.1" $1051 DAMPENERS Tiburon 09/1996-2001 4 CYL $465 STRUT TOWER BRACE Tiburon 2000-2001 RD2 FRONT $75 QUICK SHIFTER Tiburon 1997-2001 5spd $136 ALUMINUM FLYWHEEL Tiburon / Elantra 96-7/99 41mm CRANK 2.0L 4cyl $429 Tiburon / Elantra 7/99-2005 35mm CRANK 2.0L 4cyl $429 STEEL INSERT Tiburon all above FLYWHEEL STEEL INSERT REPLACEMENT $117 TURBO SYSTEMS Tiburon NON VVT STAGE I, APROX 42% POWER GAIN, 2.0L NON VVT $2414 Tiburon NON VVT STAGE II APROX 200HP@WHEELS 2.0L NON VVT $3294 CAM GEARS ALL 1.8L & 2.0L ENGINE CLEAR $120 ALL 1.8L & 2.0L ENGINE RED $120 ALL 1.8L & 2.0L ENGINE BLUE $120 COLD AIR INTAKE Tiburon 1997-2002 4cyl $217 CRUISE CONTROL Tiburon 1997-2005 ELECTRONIC CRUISE CONTROL & CRUISE LEVER $230 RADIATOR CAP COVER ALL MODELS ALL YEARS T6 ALUMINUM RADIATOR CAP COVER $36 BACK-UP SENSOR ALL MODELS ALL YEARS REAR BUMPER BACK-UP SENSOR $225 SEAT HEATER ALL UNIVERSAL FITS ALL MODELS TBA Exhausts I will be looking for cars shortly...as close to factory equiped as possible. Cars in will need to be made available for at least one week. Location is in the Southern California area (714/909) the price for the Elantra 2.0 99-00 is $349. The compatability will have to be verified. All stock HP & TQ figures are based on MFG. ratings, BSE calculations are based on wheel HP on a chassis dyno and converted to cranshaft numbers. Surface mount (SF MT) requires ECM to be shipped to BSE for install. Prices sudject to change. Prices do not include shipping. **if I missed anything, please let me know** |
how does the backup sensor work? are the cam gears adjustable?
<div class='quotetop'>QUOTE (long @ Sep 28 2005, 07:30 AM)</div><div class='quotemain'>how does the backup sensor work? are the cam gears adjustable?
<div align='right'><{POST_SNAPBACK}></div></div> I'll see if I can get a little discriptiong and pic ture for that stuff. I know we have one that comes with a new rear view mirror with a screen built in. I'll get the specs also on the gears. |
the gentex mirror with that little monitor in it is stupid expensive. but then again, thats a high price for just a proximity sensor.
got any weights on the flywheels? |
Cam gears are adjustable 12 deg. Right now NOT recomended for VVT.
Flywheels.. I dont have the weight.. but I will Find out. I know my flywheel, clutch cover and disk were 25lbs lighter. But then again I had the dual mass to start with. I'll try to get some weights. the back up mirror..I'm making something for my bike... |
Whats the ECU price
I posted that last message a month ago, still no response. I am very interested in you products if you get your website up 100%
I'd PM them.
Bill and Steph have told me they will come and post here, but still haven't. |
you want the price for the 2000 Elantra ECU right?
yeah, considering it works on the rd2
| All times are GMT -6. The time now is 07:23 AM. |
