Vendor's Booth: General
Perfect Power PRS 2&4 Wiring
Old Apr 20, 2006 | 10:31 AM
Hyundai4g63T's Avatar
Vehicle: Had 96 Elantra Wagon
Default Perfect Power PRS 2&4 Wiring
Here is the diagram (I left it big so that the writing can be read):
I will also post a basemap with the needed global settings that need to be changed aswell. If you have any questions please ask so I can get you up and running.
Also on the Diagram you must wire it with new Wires running to power the injectors, coils and Fuel Pump, this will save you alot of headache and will save time. And yes you will need to Purchase 3 30amp relays, I got mine from Radioshack and they are Cheap.
Old Apr 25, 2006 | 10:01 AM
JonGTR's Avatar
You're showing F5 and F7 powering the injectors. But then on the other side, you're showing the injectors getting powered by the relays. huh.gif
Old Apr 26, 2006 | 07:26 AM
The F5 and F7 are the grounds that pulse the injectors. I kow we discussed this on AIM but I figured I would post the info here aswell. wink.gif
Old May 14, 2006 | 03:56 PM
JonGTR's Avatar
The fuel pump power wire on the Tib is Pink w/White stripe, not yellow.
But make sure to double check because Hyundai sucks with color designations. rolleyes.gif
Old May 15, 2006 | 07:04 AM
Yeah I need to put a disclaimer cause in the years between 96-01 Hyundai changed wiring colors too much.
