Here are some pics of the Hyundai Beta Basic Kit, Look for more pictures to be added soon:
http://www.speed-factor.com/pictures...S2010007-1.JPG http://www.speed-factor.com/pictures...S2010008-1.JPG http://www.speed-factor.com/pictures...S2010009-1.JPG This is on a Automatic so you can see the clearance and there is also a Slimline fan installed to show that there is clearance. Also you can see the new placement of the BOV which is closer to the compressor housing to relieve the pressure as to reduce the back spooling effect that can occur with the placement on the upper pipe. There will be new revisions to the extreme kit to place the BOV before the Intercooler. |
How does it run without spark plugs? :?: Do you have to relocate the battery? (couldn't tell what was sitting where the battery was, pipe?)
No that motor is blown in the car hence the plugs not being in there, and no the battery doesn't move same spotjust not in the pictures.
is that a stock radiator? it looks a little wierd...
the motor looks tilted a little bit to me man... must just be me
i think its just cause its blown and its being taken apart/exploded, the intake manifold looks level to me.
Yeah the valve cover was lifted in the front if you look you can see it, and the rad is a aftermarket metal endtanks.
Lookin good Tim.
