Adjust the height of your Veloster in seconds with KSport Air Suspension Systems!
Air suspensions are widely used on sport cars, SUVs and regular cars offering a great ride comfort and ability to change the clearance with a touch of a button. If this is something that you want for your Hyundai Veloster, then KSport Air Suspension systems are worth your attention. They provide ride height adjustment of 4.7 to 7.8 inches which is perfect for daily driving and track use. These air suspension kits are designed for easy bolt-on installation and require no serious modifications (modifications may be required only for air line routing).
All KSport Airtech Systems use VIAIR compressors, and can be raised from the lowest setting to max height in as little as 2 seconds. They also include KSport’s monotube coil over dampers with air bags that are pre-installed from the factory. All dampers utilize billet, 6061 aluminum components with zinc electroplated steel shafts that are resistant to salt, rust, dirt and other harmful environmental conditions and offer 36 levels of adjustment. KSport® - Airtech Basic™ Front and Rear Air Suspension System https://www.carid.com/ic/ksport/susp...n-system_0.jpg KSport® - Airtech Pro Plus™ Front and Rear Air Suspension System https://www.carid.com/ic/ksport/susp...n-system_0.jpg KSport® - Airtech Executive™ Front and Rear Air Suspension System https://www.carid.com/ic/ksport/susp...n-system_0.jpg KSport® - Airtech Deluxe™ Front and Rear Air Suspension System https://www.carid.com/ic/ksport/susp...n-system_0.jpg If you're interested in leading-egde technology, at a competitive price KSport Air Suspension Systems are must-have for your Hyundai Veloster! |
| All times are GMT -6. The time now is 09:01 AM. |
