Scoupe's 2001 Tiburon
Vehicle: 2003 Tiburón GT
I have been slaking on my "build" thread for a while now. the vehicle is a 2001 Hyundai Tiburon with every option available( which weren't that many :biggrin: )
I purchased the car around Sept '13 for $300 with a busted front left wheel bearing, grinding 3rd gear and dented passenger door with a really shitty massive over-spray all over the passenger side. being the optimistic person that I am, I saw the potential in it.... i lied to myself telling me it could be done cheaply... this will be officially the first time I'm going to assess the somewhat long parts list.
Engine and Transmission:
NGK V-Power cooper plugs (OE)
OEM plug wire set
Replacement coil pack( random brand from amazon)
slave cylinder(already bad and I still have an OEM one from my RD1)
clutch master cylinder( still in the box)
SS Braided clutch line (not installed)
02 XD Tranny
Bahnof Stage 3 Clutch kit (claims it can hold 285 ft lb of tq (we'll see about that))
Fram Air filter
Wix fuel filter
OEM oil filter with mobil 1 oil
Torque Solutions shifter cable bushings
Megan Racing Short Shifter( currently sporting the oem one since the megan one doesn't include the bottom bushing/spacer and the shifter slop is horrible)
Die hard Battery
Alternator
ps, water pump, a/c belts
Redline MT-85 fluid
Radiator Fan
Brakes and suspension:
new OEM brake calipers all around
cheap basic rotors
power stop ceramic brake pads
Goodlridge SS brake lines
ATE brake fluid
new e-brake cables
F/R strut bars
Monroe struts
Apex lowering springs
Strut mounts
strut bellows with boots
oem swaybar bushings f/r
sway bar links
both front LCA
both rear LCA
Driver side Front knuckle (mayor p.i.t.a. to find one with abs)
Exterior:
passenger side door ( lucked out to find one locally the same color)
Turbulence side skirts
CDM SE spoiler aka Type R spoiler
GT Tech front lip
Club GTR rear pods
KDM clear corners
LEDs all around except corners and tails
5000K HIDs lowbeams
3500k HIDs fogs
new OEM Foglights with yellow tint
Scoote hood (I plan on getting rid of the scoop part because I find it wierd looking)
Wheels and Tires:
summer
Varrstoen V1 15x8 +22
Firestone Firehawk Wide Oval Indy 500 195/55-15
Dunlop Direzza DZ 102 195/55-15
winter
stockers with Hankook iPike 195/55-15
Interior:
replaced the top driver side leather skin
GK metalgrain pedals
Vision gun metal round shifter
real leather shift and e-brake boot
new old stock korean floor mats
led map lights
led trunk light
GK FL2 Steering wheel with working airbag and horn
Sony HU
EDM OEM heated seat switches
universal heated seats kit
performance parts:
AEM ebay knockoff CAI with Injen filter and Injen HydroShield filter sock
(none of this part are installed at the moment)
3" System Upgrade Catback
System Upgrade Turbo manifold
Precision GT3259E turbo
Tial 38mm wastegate
KFX PnP Megasquirt
Evo 8 OEM intercooler
Turbonetics T-bolt clamps( i know it's not really a performance part)
New old stock unorthodox racing under drive pulley
Innovate LC-3 Wideband
Autometer Cobalt mechanical oil pressure gauge
triple gauge pod
there might stuff I'm missing and I will update it as I remember.
OEM plug wire set
02 XD Tranny
Fram Air filter
Wix fuel filter
Die hard Battery
Alternator
Redline MT-85 fluid
Radiator Fan
cheap basic rotors
ATE brake fluid
new e-brake cables
F/R strut bars
Monroe struts
Strut mounts
sway bar links
both front LCA
both rear LCA
Exterior:
GT Tech front lip
Club GTR rear pods
KDM clear corners
5000K HIDs lowbeams
3500k HIDs fogs
Wheels and Tires:
summer
winter
Interior:
led map lights
led trunk light
Sony HU
performance parts:
Tial 38mm wastegate
KFX PnP Megasquirt
triple gauge pod
more parts that I forgot to add.
triple gauge pod
Redline MT-85 fluid
Radiator fan
OE Style replacement flex pipe
I had the MS on the car last summer and it ran fine but needed some fine tuning with the timing and for some reason the car rarely started on first try. still need to wire the launch control and wideband.
triple gauge pod
Redline MT-85 fluid
Radiator fan
I've been looking to do this for a while but I never found what I was looking for(specific info on the matter) until the recent thread. I know that it takes more than just installing them to make power. I have been reading on runner length and harmonics. Also i am looking to boost my car so some might see it as a waste of time building an ITB setup just to go boosted after.
anyways this is what i have. 05 Kawasaki ZX-10R throttle bodies IIRC they are about 42mm ID and only have a single butterfly. The velocity stacks have the same id and taper to 50mm (i think).
I am looking for an oval to round transition to keep the throttles as straight as possible.
1 Post
Im not on alot anymore but let me know when you get that Megasquirt from KFX hooked up I can get some basics from you and hopefully get you a decent starting point base map. Looking good by the way. Nice to see another silver 01 still around
