My 2g Dsm Project
Old Mar 12, 2009 | 06:29 PM
  #21
rd2pimp's Avatar
just got done installing radiator and ralco rz 4 piece underdrive pulley kit.
and i have some questions
1. is there any way to run wiring to my fans with out running a relay off the ignition switch? (orignal is 4 wire fan harness new has 2 wires)
2. does anyone know if the 255lph walbro sold for the tiburon will work on a 2g? (i have one laying around)
3.what companies make car specific seat covers?
Old Mar 12, 2009 | 07:10 PM
  #22
Alton87's Avatar
A place called katzkin leather always gets featured on t.v. shows like trucks and gearz on speed network and spike t.v. with Stacy David. They do all the leather for the custom interior on those vehicles, pretty cool stuff they do but im not sure how much the covers would cost. But i guess its worth checking out, so here's a link. katzkin leather Hope this helps you out some fing02.gif
Old Apr 26, 2009 | 01:34 PM
  #23
rd2pimp's Avatar
just figured id stop in and give an update on the the eclipse
so far heres the mods list
ebay intake
speed action headers and o2 housing
mandrel bent 2.5 to 3"down pipe
3" mandrel bent exhuast
2.5" full intercooler piping
fmic
greddy type rs bov w/ recirculating adapter
ralco rz underdrive pulley kit(crank,water,p/s,alt)
cxracing radiator w/ 2 12" fans
obx fuel rail
stm high flow fuel filter and feed kit
weapon r sheet metal intake manifold
hallman pro rx manual boost controller
saikou michi dual oil catch can
eliminated cruise contol
eliminated evap system
moved battery to trunk
some pix
future mods
boost,oil pressure,wideband gauge
750cc injectors
walbro 255 fuel pump
aem fpr(sitting in garage)
precision t&e scm5031 turbo
dsmlink
god speed sway bars
poly bushings all the way around
let me know what you think
Old Apr 26, 2009 | 02:15 PM
  #24
Bommello's Avatar
Looks good man.... Hurry up and finish both cars!!! lol
Old Apr 26, 2009 | 02:57 PM
  #25
The Tiburon fuel pump is a 2G style pump so you can use it
Old Apr 26, 2009 | 03:28 PM
  #26
rd2pimp's Avatar
Bommello- im working here man! lol tib would already be done if it wasnt for shitty fitment and me having to add fiberglass to the fenders and the bumper just to get it to bolt up right
ericy321=i thought so from what i have heard, just havent had time to pull the stocker out of the eclipse to check. also, would i have to re-wire it or will it just plug in?
thanks for the info
Old Apr 26, 2009 | 03:33 PM
  #27
Will plug in but you should run a new 12gauge hot wire to it and use a relay off the stock wiring. Those are known to burn up stock wiring.
Old Apr 26, 2009 | 03:51 PM
  #28
Roadwire does model specific seat skin replacements, that's who I got mine from through KfxPerformance. They can get those for you too.
Old May 12, 2009 | 09:06 PM
  #29
rd2pimp's Avatar
well this has been my project for the past couple days
painted gauge cluster and surround
oil pressure and boost glowshift elite gauges
acautotechnic s7 gauge faces
blue led turn signals
real carbon guage bezel
glowshift cluster surround
greddy full auto turbo timer
i did have a question about the turbo timer though.
for some reason when i start the car the unit powers up and functions correctly. but i just cant seem to get it to keep the car running at all when i turn the key off (wont countdown and shut off just shuts off) is there a step in setting this thing up that i could have forgotten? i used the 2g greddy harness and it has a good ground. im just so confused with this thing.
Old May 13, 2009 | 04:48 PM
  #30
gophins349's Avatar
i do not know anything about turbo timers but sounds like might be wired up wrong, or maybe you have to calibrate the rpms.
just my .02
