The life of BlueSpanishShark (AKA BlueTurboShark now)
WHP stages of my car. I'm the first owner and I have 167,000km on it.
1. Off the lot Stock beta auto transmission (104WHP), 2. Stock beta engine with dim sports re programable ecu (115WHP) 3. Stock beta engine, first stage of the turbo HKS GT2510, headers etc. and tuning maps on the dim sport (160WHP @ 4psi) 4. Stock beta engine, swapped auto transmission to manual transmission, standlone Haltech E8, 350cc injectors, and more tuning (220WHP @ 9psi) 5. Stock beta engine, new duel friction clutch, upgraded spark plugs, HKS Twin Power, more tuning (259WHP @ 13.5psi) 6. Finally Stock beta engine as of yesterday, new Deatschwerks 320LPH fuel pump, Injectordynamics 720cc Injectors and more tuning. (299WHP, 306lbs torque @ 15psi...translation 373ish HP). Full list of upgrades. Performance: HKS: Gauges: Electronic 46mm EGT Warning Mechanical 46mm Boost Electronic 46 mm Temperature Warning Warning Monitor module Boost Controller: New EVC (Electronic Valve Controller): with Display Unit and Control Module. Custom center console made for Gauges and EVC. HKS Wide Band Sensor: A/F Knock Amp with its built-in digital display and face mounted controls. O2 Sensor Lean Burn 32 bit system. O2 Sensor Harness (3M). Knock amp is in glove box and display unit is mounted on the dash (in April mount it in a custom place, permanent). HKS Ball Bearing Turbo: GT2510 Turbo HKS Intercooler: 400x126x68 core Aluminum piping HKS Super SQV HKS turbo timer type 0 HKS Carbon Ti Muffler Centre Force: DUAL FRICTION Performance clutch Others: Mantec turbo manifold. Haltech E8 (Standalone management system) KOYO Rad B&M Oil Cooler Oil Relocation Kit Injectordynamics 720cc Injectors Deatschwerks 320LPH fuel pump Fuel Gauge (engine bay) NGK Iridium IX Spark plugs NGK Spark plug wires Custom: Custom Mandrel bent exhaust piping Custom downpipe Auto to Manual swap Suspension/Brakes & Wheels ARK Front/Rear Strut tower brace ARK DT-P Coilover system NRG engine dampener 17x7 Work Emotion CR-KAI wheels Kumho ECSTA SPT 205/40ZR/17 tires XG350 big brake conversion Cquence Performance Cross Brake Rotors Stereo Eclipse CD3200 (SAT Radio Ready, Bluetooth and USB port) Show CF VIS Invader Hood GT R 34 Bayside Blue Paint job HKS Oil Cap Bosch HID Conversion Kit 8000k for low and fogs. https://lh5.googleusercontent.com/-f...+final+032.jpg Before I was maxed out on fuel running 259WHP but now we have tons of room with the new injectors. Like I said I have 299WHP @ 15psi (373ish HP) Run 33 was near the start of the re-tunning of the new injectors just to show how much it went up Run 49 was the best run and what we saved the maps at. This stock motor is amazing........;) Dyno video to follow https://lh3.googleusercontent.com/-y...2/IMG_0004.jpg |
:thumbup: Good stuff!
wow.. i appreciate you putting in the HP increments with the milestone mods you did :)
kind of an ignorant question but how did the A/T hold up during point 3 when you had turbo installed? |
It did very well but I never pushed it to see when it would fail.
When I swapped it though after a year the clutch started slipping. |
Nice build!
Good stuff mate. How much pressure are you going to run through the stock engine?
I have been running 14 for two years now
Dyno Run [media]http://www.youtube.com/watch?v=maIMvWMBK1Y[/media] |
Those are some nice hp & tq numbers.
One of my favotite Tibs!! , Great work man !, Love it !:thumbup:
Great job!
| All times are GMT -6. The time now is 05:28 AM. |
