The life of BlueSpanishShark (AKA BlueTurboShark now)
Old Dec 12, 2012 | 01:07 AM
BlueSpanishShark's Avatar
Vehicle: 2000/Hyundai/Turbo Tiburon
Default The life of BlueSpanishShark (AKA BlueTurboShark now)
WHP stages of my car. I'm the first owner and I have 167,000km on it.
1. Off the lot Stock beta auto transmission (104WHP),
2. Stock beta engine with dim sports re programable ecu (115WHP)
3. Stock beta engine, first stage of the turbo HKS GT2510, headers etc. and tuning maps on the dim sport (160WHP @ 4psi)
4. Stock beta engine, swapped auto transmission to manual transmission, standlone Haltech E8, 350cc injectors, and more tuning (220WHP @ 9psi)
5. Stock beta engine, new duel friction clutch, upgraded spark plugs, HKS Twin Power, more tuning (259WHP @ 13.5psi)
6. Finally Stock beta engine as of yesterday, new Deatschwerks 320LPH fuel pump, Injectordynamics 720cc Injectors and more tuning. (299WHP, 306lbs torque @ 15psi...translation 373ish HP).
Full list of upgrades.
Performance:
HKS:
Gauges:
Electronic 46mm EGT Warning
Mechanical 46mm Boost
Electronic 46 mm Temperature Warning
Warning Monitor module
Boost Controller:
New EVC (Electronic Valve Controller): with Display Unit and Control Module.
Custom center console made for Gauges and EVC.
HKS Wide Band Sensor:
A/F Knock Amp with its built-in digital display and face mounted controls.
O2 Sensor Lean Burn 32 bit system.
O2 Sensor Harness (3M).
Knock amp is in glove box and display unit is mounted on the dash (in April mount it in a custom place, permanent).
HKS Ball Bearing Turbo:
GT2510 Turbo
HKS Intercooler:
400x126x68 core
Aluminum piping
HKS Super SQV
HKS turbo timer type 0
HKS Carbon Ti Muffler
Centre Force:
DUAL FRICTION Performance clutch
Others:
Mantec turbo manifold.
Haltech E8 (Standalone management system)
KOYO Rad
B&M Oil Cooler
Oil Relocation Kit
Fuel Gauge (engine bay)
NGK Iridium IX Spark plugs
NGK Spark plug wires
Custom:
Custom Mandrel bent exhaust piping
Custom downpipe
Auto to Manual swap
Suspension/Brakes & Wheels
ARK Front/Rear Strut tower brace
ARK DT-P Coilover system
NRG engine dampener
17x7 Work Emotion CR-KAI wheels
Kumho ECSTA SPT 205/40ZR/17 tires
XG350 big brake conversion
Cquence Performance Cross Brake Rotors
Stereo
Eclipse CD3200 (SAT Radio Ready, Bluetooth and USB port)
Show
CF VIS Invader Hood
GT R 34 Bayside Blue Paint job
HKS Oil Cap
Bosch HID Conversion Kit 8000k for low and fogs.
Before I was maxed out on fuel running 259WHP but now we have tons of room with the new injectors. Like I said I have 299WHP @ 15psi (373ish HP)
Run 33 was near the start of the re-tunning of the new injectors just to show how much it went up
Run 49 was the best run and what we saved the maps at. This stock motor is amazing........ Dyno video to follow
Old Dec 12, 2012 | 08:07 AM
Good stuff!
Old Dec 12, 2012 | 08:48 AM
mousepad's Avatar
Vehicle: 1997 hyundai coupe
wow.. i appreciate you putting in the HP increments with the milestone mods you did
kind of an ignorant question but how did the A/T hold up during point 3 when you had turbo installed?
Old Dec 12, 2012 | 09:38 AM
It did very well but I never pushed it to see when it would fail.
When I swapped it though after a year the clutch started slipping.
Old Dec 12, 2012 | 10:01 PM
2FastElantra's Avatar
Vehicle: 2005 Hyundai Tiburon GT
Nice build!
Old Dec 13, 2012 | 01:35 AM
wheel_of_steel's Avatar
Good stuff mate. How much pressure are you going to run through the stock engine?
Old Dec 13, 2012 | 01:31 PM
I have been running 14 for two years now
Dyno Run
[media]http://www.youtube.com/watch?v=maIMvWMBK1Y[/media]
Old Dec 14, 2012 | 11:45 PM
DohcBeta's Avatar
Vehicle: 2004/Hyun/Elantra
Those are some nice hp & tq numbers.
Old Dec 15, 2012 | 03:06 PM
Regit's Avatar
Vehicle: 2000 tib
One of my favotite Tibs!! , Great work man !, Love it !
Old Dec 16, 2012 | 09:36 PM
DJgiggle's Avatar
Vehicle: 2003-Sonata
Great job!
