Hyundai Aftermarket
-   Turbo & Supercharge (Forced Induction) (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/)
-   -   White Smoke When Shifting (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/white-smoke-when-shifting-49296/)
bassboy3313 Sep 7, 2008 01:38 PM
Hey. After getting everything running right on my turbo project, I have white smoke coming out of the tail pipe when shifting. I will hit the clutch, shift, and when I get back onto the accelerator a puff of white smoke comes out. What could this be?
Role Reversal Sep 7, 2008 01:47 PM
is it white or does it have a little bit of a blue tint to it. if it is white then most likely coolant leaking somewhere. if it is slightly blue then oil is leaking somewhere.
mwood Sep 7, 2008 02:20 PM
check the down pipe for oil...to make sure the seals on the turbo are not going out
yamaha Sep 7, 2008 02:56 PM
Check your vacuum hookup to your valve cover as well.
bassboy3313 Sep 7, 2008 04:55 PM
<div class='quotetop'>QUOTE (ABQelantra @ Sep 7 2008, 02:47 PM) <{POST_SNAPBACK}></div><div class='quotemain'>is it whte or does it have a little bit of a blue tint to it. if it is white then most likely coolant leaking somewhere. if it is slightly blue then oil is leaking somewhere.</div>
It only happens when I drive it, so i cant really see if there is a blueish tint to it. Would the blue be noticeable from inside the car?
mwood Sep 7, 2008 05:14 PM
have someone follow in parking lot or something to see the color of the smoke
SOCKS_old Sep 7, 2008 05:38 PM
im betting its bluish white, not white.. which means oil.
could be your seals.. how low is your fitting in the oil pan? how is your feed hooked up?
did you do anything different with your valve cover and PCV vent when you boosted? like catch can or anything? how'd ya hook it up.
but just from your post, my money is on the seals having a) too much pressure from oil feed b) oil return line is too low in pan, not letting it drain.
if thats true, you are probably in need of a new turbo or if it is the return line fitting being too low, you will have to do that over and pray that the seals aren't toast yet.
bassboy3313 Sep 7, 2008 07:27 PM
The fitting is about an inch into the pan. My feed is hooked up from a sandwich plate on the filter and has a restrictor on the turbo end of the line.
I did not touch the valve cover or PCV vent.
DTN Sep 7, 2008 07:36 PM
You should put a check valve in your PCV so that you're not boosting your engine block. Also, vent the breather to atmosphere. I've been looking at alot of stock turbo setups. They all have check valves. It could be that the extra boost pressure is forcing oil through the oil pump and causing an increase of pressure on the turbo, which causes failure of the turbo seals. I noticed alot of tibs have a problem with that, and noone seems to put a check valve on their car.
If it is in fact white smoke, you should see the problem at high rpms or low RPMs. You should be able to see bubbles in your coolant. If it's blueish smoke, then you should be able to find an oily residue in your exhaust pipe and you will have a check engine light stating that your emissions have gone to crap because you're buring oil somewhere and it destroys your catalytic pretty quickly. If it's grey/black smoke then you're running rich and a wideband o2 sensor should be able to tell you.
Denisst99 Sep 8, 2008 11:01 PM
if you go UBER rich when shifting it can be caused by too much fuel
havea wideband hooked up?
