What is this out thing for? its from a turbo Tiburon....
What is this for? its from a turbo tiburon, i know that the oil feeds, comes from the block ( up ) and the other goes to the oil pan, right? but this???
hope the pic show up......
if this dont show up, can somebody tell me how can i upload a pic?
thanks
thanks
I don't see a pic, but if there's another input/output line on the turbo, then it could be the coolant line.
QUOTE (JonGTR)
the pic didnt came out, but its was a poc of the down part of the engine.... up from the oil pan... right in the block.
i will try to put the pic from the page where i saw it...
http://www.cardomain.com/memberpage/281537/4
the second pic....
thanks for you help
if the onwer of his car doesnt want to use his pic, send a pm and i will take off of this page.
QUOTE (Voiddweller)
QUOTE (Mad-Machine)
that oil drain looks a little low on the pan. It should be above the oil level to let the turbo drain properly
Yeah, that is very true as well. I didn't even think about that.
so?!, the oil feed back it must goin the block engine like this pic, and not in the oil pan?? like the pic number 7 ??
and if anyone know where can i put the BOV and wastegate lines??
thanks
That is 2Uniqs Tib with the Alpine Kit. The fitting in the block is for the oil return line from the turbo, the feed for the turbo comes from the head. The hole in the oil pan to my knowledge he used for his oil temp gauge probe, that is why it is so low in the oil pan. Myself I decided to route the oil feed into the the upper part of the oil pan rather than drill into the block. smile.gif
