twin turbo zet on tiburon
Old Jul 21, 2002 | 03:38 AM
tibboy316's Avatar
Default twin turbo zet on tiburon
yes i know many of you are going to want to kill me for buying this but for 100 bukcs i was curious
1. Cut the air hose between Air cleaner (With Airflow sensor) and throttle body, and insert TURBO Zet, and clamp with band. (See picture * 8 *)
2. If necessary, please use other kind hose for fitting (Every car has different hose).
3. If you cannot install at hose between filter and surge tank, because of round hose or square hose, please install before filter (for ex. Carburetor).
It does not decrease efficiency.
4. If space is not enough, then you can cut the outlet pipe of TURBO Zet little bit.
5. If necessary, you can modify hose or some other fitting.
where excally would this be and is it possible??(post a pic with area highlighted smile.gif )
One wire to AC+DC 12volt (same PP 300volt) of ignition coil input (diesel: fuel pump s/w key) line and another to body ground.
i know where igintion coil is located aprox. but i dont know excally what it looks like so could someone tell me?
Old Jul 21, 2002 | 09:17 AM
Greenchaos's Avatar
he's not really asking for opinions on the product he's asking for install help. and if you do a search all you will mostly get is a bunch of they suck post.
Old Jul 21, 2002 | 02:00 PM
This has been discussed before and beat to death. Search the forum if you want to read everyone's opinion, I'm not going to let anyone keep posting more drivel here. I'll keep deleting any replies that don't directly address the question of how to install.
You would have to install it AFTER the MAF and before the TB.
Post up a link to your favorite engine photo, and I'll modifiy it to show you where.
