turbo help low rpm stalling
Well I am getting my sliver RD ready for spring and I am have problems with stalling out at low rpms. Is this a problem with the map and not getting enuff fuel. Or could it be the alternator? The tranny is bad to so could it be that the cluch is not engaging right? I am running GT28RS and haltech E6k. Thank you for any help.
I have wideband. it does it when it dips blow 1k rpm in gear or cluch push in. And i get read outs of 14-15 then it will clear out. But that what is reads at idle at 1k in nurtral.
Ill have to check the Idle Air Controller when i get home.
It has been siting for few months could the fuel have gone bad?
Vehicle: 01 Tiburon
QUOTE (xxxmonoxidechild @ Mar 23 2007, 02:53 PM)
how is the IAC hooked up
QUOTE (peter_2150 @ Mar 23 2007, 04:08 PM)
Im pretty sure that the silver car wont have an IAC. It's standalone!!!
Maybe you need to re-tune it again
I found the ISC. Any way I think it just need to be tuned to (I hope). I am going to try to play around with the map little. The closest shop is 2 hours way =X so it is hard for me to get down there.
