stock MAP sensor question
On Kefico web site I found diagram of stock MAP sensor, here is it:
The last point is 110 kPa (1.1 Bar, 16.2 psi).
16.2-14.7=1.5 psi , so this sensor will be ok only for 1.5 psi boost? Is it true? If I want to get 8-10 psi boost should I have another PAM sensor (2 bar sensor for example)?
