Smt-6 Wiring
Old May 11, 2009 | 01:56 PM
hamhead's Avatar
Does anyone have a base map for the SMT-6 Unit? I intend to run stock injectors + the fifth injector (650cc I believe) setup from the Unichip, so I'm basically just wiring in the RPM, TPS, Power, Ground wires in the SMT-6 along with using the T-module off the Unichip as a MAP sensor (anyone know whether its a 2 bar or 3? I'd assume 2).
Side-note: I can connect to the SMT-6 online just fine, so I'd imagine the power/ground is fine. However, my rpm reads 35 at idle and my throttle deflection is 3.3%. Throttle deflection doesn't change as I press the pedal. RPM goes up, but reads like 90 at 2000rpm. Any ideas on that, or is that just because I haven't scaled them yet?
Old May 11, 2009 | 03:01 PM
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
I have some MAPs, send me a PM.
Old May 14, 2009 | 01:00 PM
David Dickson's Avatar
How did you wire in the SMT-6? If your going to use sub injection then you will not be able to control timing and need to wire it as such.
FYI, the Turbo Module is a 2.5 Bar MAP, the MAP output wire is the pink one.
Now that you mention it I wonder if by using the injector driver in the turbo module if you could somehow get both Injection and Igntion to work on a Beta1 ECU....hmmmm
