Hyundai Aftermarket
-   Turbo & Supercharge (Forced Induction) (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/)
-   -   Quick Question (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/quick-question-27867/)
a_gut Apr 11, 2005 01:15 PM
What size allen wrench do I use for oil line key hole (turbo oil line)? I have a 5.0, but it seems a bit loose and I dont want to strip it.
Also, how does the oil pan come out? I got all the bolts off, even the ones by the flywheel, and that mug is stuck on there like no other.
Edit: Okay I got the oil pan off and got a surprise. Found these inside:
http://img4.imagevenue.com/loc45/th_b46_oilPan1.JPG http://img3.imagevenue.com/loc181/th_75f_oilPan2.JPG http://img5.imagevenue.com/loc256/th_22d_oilPan3.JPG http://img7.imagevenue.com/loc93/th_f3e_oilPan4.JPG
I have a feeling those aren't supposed to be sitting inside the oil pan wink1.gif So, what are they?
albert Apr 11, 2005 03:13 PM
The oil pan is "stuck" on with adhesive, so you'll need to pry it off.
The allen is a 5.5 if I remember right. It's also soft brass stuck on with locktite. You'll need to take a blowtorch to the brass fitting and heat it to over 300 degrees to break/cook the locktite off.
