NUTTANICK's engine pics
This is my engine pics.(beta 1)Has anyone got beta 1 engine with turbo set.
http://groups.msn.com/NUTTANICK/myhyundaie...tra.msnw?Page=1 NUTTANICK's beta turbo |
<div class='quotetop'>QUOTE</div><div class='quotemain'>NUTTANICK PREMBOON:
Has anyone got beta 1 engine with turbo set.</div>Uhh.. yup. tongue.gif Nice setup! |
Cool man.
Can we get some specs. On your rims and tires. type and size and what kind aboost you making. CR and dyno whp? |
I had installed Skyline R32 brake rotor and caliper to my Elantra so my wheel PCD is 5x114.3
3 pieces Volk racing wrap with falken 215/45/zr17 Don't get confuse about the of using Skyline rotor and caliper.My idea is the cheapest and good performance and because of to make any custom made for your car in Thailand is so cheap.My suspension are Hypercoil springs No 650 3inch;di/10inch;le with custom revalve and piston,No 450 3inch;di/10inch;le again with custom revalve and piston. My beta still stock CR but running only less than 5psi for two years and will rebuild with better piston set in feb.One of the tuner shop said I could use used Mitsu Rally art with his custom piston pin. But he's reccomments to swap engine to Mitsu Evelution 6 or 7 4G63T Likes the orther tuning shops reccommented. |
Nuttanick, nice job!
How did you fit 215/45/zr17
Dont they rub on turns? |
Yeah, good point there. I run 215/40R17's and they rub. What did you do?
Sorry! Wrong info my tire is 215/40/zr17 It isn't rub on turn but It'll rub when jump.I had put some polyurathane about 2.5inch around my shock shaft to limit shock so my shock can moved only 1.7 inch and with some mod to my body.
Uh...where in the heck did you get that strut tower brace? I've been searching and searching for a triangulated unit like that, but been unable to find one. Did it come with that mounting brace for the firewall?
It is TOMEI tower bar made for 180SX. For the installation I'v add a pair of spacer to my Elantra strut tower. A little more add about 0.5kg but in that time nothing available for Hyundai.And it's cheap(used)about 40usd.
| All times are GMT -6. The time now is 08:34 AM. |
