N/a Power!
Old Jun 14, 2006 | 11:24 AM
holeshot69's Avatar
Vehicle: 1998 Tiburon
Lets pics and lists of people runnin n/a! Results on dyno and average price would be kool as well!
Old Jun 14, 2006 | 01:48 PM
You won't see much here. Most folks get so upset with N/A power on the beta they never post anything.
Expect to pay about 5 to 10 grand to get about 175 to the wheels.
Old Jun 14, 2006 | 03:13 PM
xxxmonoxidechild's Avatar
thats insane....... with a higher compresion set up, and custom tuning, i think 200whp n/a should be pretty feasible done right.
Old Jun 14, 2006 | 03:49 PM
tdonnell's Avatar
Well, here is the list:
Speed Performance Modifications:
AEM CAI
65mm TB
Airram IM
Outlaw Phenolic Spacers
SR Hi Cams 268 Deg Duration IN/EX 9.2mm lift
SR Cam gear and power steering, water pump, and Underdrive pulleys
HVE Stage 1 4-1 header
Custom 2.5" HEADER back exhaust
2.5" high flow magnaflow cat
thrush glasspack (no ricer buzz)
3" race core magnaflow muffler
B&M SS
Nology Hotwires (truthfully, I think they suck)
Beru silverstone plugs
SAFC II
PLX Wideband w/datalogging
Removed rear seats and other various weight reduction
Handling Modifications:
Rotorworks D/S rotors all around
Goodrich SS braided brake lines
Ksport full coilovers
Eibach sway bars front and rear
SR strut bars, front, rear, and center
I think that is about it, if I remember anything else I will post it up.
The car went 15.2 (really should have been 15.0 or better) with 2.3 60' and about 90 mph trap speed. I need to work on my launches. Anyway, that time was before the cams so now I would expect mid to high 14's easily.
Sorry, no dyno numbers yet. Hopefully soon though, I would hope for about 140-150 at the wheels.
I would say 10 grand should get you at least 200 whp, but it probably wouldn't be streetable or runnable on pump gas.
I probably have 4-5 grand just in the speed modifications I have done, but once I get a ported and polished head, and re-flashed ecu, the mods will all start to pay off.
Old Jun 14, 2006 | 08:14 PM
Zman's Avatar
OK, here goes mine...
Custom 3" CAI with K&N
65mm TB
Airram IM
1.8 Beta intake camshaft
Maintec Racing header
Custom 2.5" Mid Pipe with 2 28" Thrush Glasspacks (no Cat required for me)
Custom 2.5" Tail Pipe
SummitRacing Stainless Steel Muffler (really great sound)
Magnecor 8mm Sparkwires
Bosh copper plus plugs
run on 97 gas (RON -whic is like your 93 more or less) all the time
RSide Short Shifter for comfort
Suspension and Brakes:
H&R springs
KYB GR2 struts
Whiteline swaybars
Rotora slotted rotors all around
EBC Greenstuff pads all around
SR rear strut bar
I don't have the dyno I made at hand, but before the AirRam and header it was 160HP; I don't think the AirRam and Header really added a lot of HPs, maybe like 5-7 all together, but they must have improved torque. The dyno I made was on a Bosh roller.
Also, remember my car does NOT (because of the country I live in) run ODBII, it does not have a catalityc converter, and no O2 sensors (it runs on an open loop injection cycle) and is not calibrated to pass emission tests; that could mean it gives a little more power with mods than US-spec Tibs. Well, anyhow, I rarely post these HP numbers because I don't want anyone to call me names for lying, that number is the one I have and I don't pretedn to be better than anyone here. fing02.gif
Old Jun 15, 2006 | 01:29 AM
lilo shark's Avatar
here's my set up
OBX 4-2-1 Headers
KRD Mid-section
HKS Rear-section
NGk Wires and Iriduim plugs
OBX Light wieght crank pulley
snorkle intake w/ K&N drop in filter
1.8l cam
Custom ground wires
Grounded Exhaust
Excedy oem clutch
Suspension:
Arrowspeed Coilovers
i hit a 15.4, probably can hit faster if i drive like a stole it.
Old Jun 15, 2006 | 08:31 AM
daoust's Avatar
and for me
ngk plug wire
bosch platine 4
b&m fuel pressure regulator
cai aem
bbtb rside 61mm
airram intake
outlaws phenolic spacer
port and polish
head shaved of 0,015 mils
3 angle valves jobs
286deg in/ex 9,5mm of lift
kspec intake cam gear
fidanza cam gear
fidanza flywhell
obz crank pulley , power stering , alternateur
obx headers 4-2-1
2 1/2 exhaust
2 1/2 hight flow cat
2 1/2 glass pack
2 1/2 borla mufler
dtmspeed ecu on the way ! tuned for 91 octane
i m still tunnig it so no number yet
Old Jun 15, 2006 | 08:41 AM
well since everyone else is doin it
engine stuff:
injen intake with brand new k&n
obx header
carsound 2.25 cat
mandrel bent 2.25 piping
thrush glasspack
dynomax superturbo muffler
b&m short throw
act clutch
fidanza flywheel
ngk plugs replaced every 5k
ngk wires
3m mounts
other stuff:
eibach springs
kyb gr2 struts
tiburon fx wheels
khumo 712s
no interior to compensate for my fat self
i ran a 16.7 at 5800 feet(adjusting for humidity index at the time it was the equivalent of racing at 8800 feet)
and that was with a shot trans that wouldnt go into second oh and the 60 foot was 2.4(i blame it on the trans...lol)
Old Jun 15, 2006 | 08:44 AM
tdonnell's Avatar
Holy crap! 286 degrees of duration! How does that thing idle and what redline do you plan on setting up? Is this a daily driver for you?
Old Jun 15, 2006 | 10:16 AM
daoust's Avatar
yes it s a daily driven car the idle is so great , everybody on the sidewalk turn their head when i m at the light and dtmspeed will set the rev limiter too match the cam , so i m still waiting for them to get updated
