Is my oil pressure low?
Old May 25, 2012 | 09:41 AM
  #21
Red Raspberry's Avatar
Originally Posted by 03tibe85
This has the words 'EPIC FAIL' written all over it. Stick with a sticker that says 'Turbo' and stay away from the real thing..lol
It's like using PVC pipe for air pressure......
Old May 25, 2012 | 10:45 AM
  #22
97dsscobra's Avatar
Vehicle: accent
Stainless steel braided is the best line you can get for oil, obviously thats why its used to feed the oil, nd im using aluminum piping.
Turbo sticker? Wtf are You talking about?
honestly if your not going to help don't post your negative stuff.
Dont turn this into a hater forum like typical honda ones.
This is obviously my first turboed hyundai I thought ppl here would freaking help.
And to those who have helped, I thank you.
Old May 25, 2012 | 10:48 AM
  #23
97dsscobra's Avatar
Vehicle: accent
Originally Posted by Red Raspberry
Usually with a mechanical gauge you either use nylon or copper line. Vinyl will explode with 60 psi.
And I correct my self it was a nylon line from autometer
Old May 25, 2012 | 11:05 AM
  #24
I've ran nylon on a mechanical gauge ack in the day, copper two. I have nylon on my boost gauge now. All are susceptible to damage if kinked. I don't know how many little brass compression collets I've used just on my boost gauge due to cutting off the end because of a kink.
But if done right the nylon is alright to use.
Old May 25, 2012 | 11:25 AM
  #25
97dsscobra's Avatar
Vehicle: accent
Yeah I had to buy a ton of those lol but after work today im going with the braided line for the oil pressure and yeah my boost/vac is nylon too.
Old May 30, 2012 | 07:17 AM
  #26
Kman Tib's Avatar
Vehicle: 2005 Hyundai Tiburon
Also did you calibrate your wideband?
Old May 31, 2012 | 06:33 AM
  #27
97dsscobra's Avatar
Vehicle: accent
No I haven't...didn't know I had to...how do you do that?
Old May 31, 2012 | 06:49 AM
  #28
Kman Tib's Avatar
well that could mean you are getting false readings. You usually have to put it in calibrate mode, with the Innovate you can install a button or ground a wire to get it in calibrate mode and you keep the O2 sensor out of the exhaust in open atmosphere for it to get the atmospheric reading then once it gets that it will indicate when it's finished calibrate mode and you can then install the sensor in the exhaust. Not sure what wideband you have but get the instructions for it and it will tell you how to calibrate it. They usually say to do this every so often just to keep it reading properly.
Old May 31, 2012 | 07:44 AM
  #29
97dsscobra's Avatar
Vehicle: accent
I have an aem brand and ill look at the instructions today.
Thanks kman!
Old May 31, 2012 | 11:39 AM
  #30
Kman Tib's Avatar
No problem, sometimes us people with more knowledge can over look basics and what comes to us as natural now so seeing as it's your first turbo project I figure I'd thow out basics that cross my mind for your situation to make sure you've went over them all. This is why I think it's good to do a build thread as people go along so issues they come accross they can be helped along the way and it's all kept in one thread for your ease of reference.
