hi, i´m to put a turbo in my car.... I need the low compression gasket for the motor....
where can i buy? other question....what sparks will i need when I have installed the turbo? now i have IX IRIDIUM SPARKS |
low compression gasket or decompression plate is not a very good way to lower compression ratio although it may run good on low boost levels.
the best way is to install low compression pistons. you can find them on: www.kspec.com www.rpw.com.au what boost pressure are you gonna run? |
now...about 7-8 PSI....i have a little t3 turbo because is the cheapest.
low compression piston for my 1.6 engine i think dont exist....if someone know where can i get it i´m pleased. and about the sparks what do you think? what sparks will i need? the kspec gasket is good? i think that will be i buy |
i don't know if it will fit your 1.6
is says: <div class='quotetop'>QUOTE (KSPEC.COM)</div><div class='quotemain'>Application -Hyundai Beta I or II 1.8L & 2.0L Engines</div> |
we really dont know to much about the 1.6 beta, so i dont know about what pistons would work.
as long as its still a "beta" though, im sure the decompression plate from alpine developments would work. someone was selling one a long time ago either here or at www.hyundaiperformance.com. you might want to do some searching through the for sale forums for it. |
yeah i think 2uniq has been selling one for years so look for that
and about the sparks? what do you recomended to me?
use one step colder spark plugs.
If stock is NGK BKR5ES, use BKR6ES but I don't know what gap should be there. |
That would be a difficult search...... Good Luck man.. I will try to search too.....
I found UK site, they make copper decompression plates and copper head gaskets, they may help you, contact them.
Ferriday Engineering |
| All times are GMT -6. The time now is 02:18 AM. |
