Low Compression Gasket
Old Nov 24, 2005 | 04:49 AM
fastuning's Avatar
Vehicle: Hyundai tiburon 1.6 TURBO
hi, i´m to put a turbo in my car.... I need the low compression gasket for the motor....
where can i buy?
other question....what sparks will i need when I have installed the turbo? now i have IX IRIDIUM SPARKS
Old Nov 24, 2005 | 05:11 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
low compression gasket or decompression plate is not a very good way to lower compression ratio although it may run good on low boost levels.
the best way is to install low compression pistons.
you can find them on:
www.kspec.com
www.rpw.com.au
what boost pressure are you gonna run?
Old Nov 24, 2005 | 05:20 AM
fastuning's Avatar
now...about 7-8 PSI....i have a little t3 turbo because is the cheapest.
low compression piston for my 1.6 engine i think dont exist....if someone know where can i get it i´m pleased.
and about the sparks what do you think? what sparks will i need?
the kspec gasket is good? i think that will be i buy
Old Nov 24, 2005 | 05:51 AM
Dmitry's Avatar
i don't know if it will fit your 1.6
is says:
QUOTE (KSPEC.COM)
Application
-Hyundai Beta I or II 1.8L & 2.0L Engines
Old Nov 24, 2005 | 09:21 AM
we really dont know to much about the 1.6 beta, so i dont know about what pistons would work.
as long as its still a "beta" though, im sure the decompression plate from alpine developments would work. someone was selling one a long time ago either here or at www.hyundaiperformance.com. you might want to do some searching through the for sale forums for it.
Old Nov 24, 2005 | 09:23 AM
yeah i think 2uniq has been selling one for years so look for that
Old Nov 24, 2005 | 10:05 AM
fastuning's Avatar
and about the sparks? what do you recomended to me?
Old Nov 24, 2005 | 10:29 AM
Dmitry's Avatar
use one step colder spark plugs.
If stock is NGK BKR5ES, use BKR6ES
but I don't know what gap should be there.
Old Nov 24, 2005 | 12:25 PM
TiburonWao's Avatar
That would be a difficult search...... Good Luck man.. I will try to search too.....
Old Nov 24, 2005 | 12:47 PM
Dmitry's Avatar
I found UK site, they make copper decompression plates and copper head gaskets, they may help you, contact them.
Ferriday Engineering
