A Little Update
Vehicle: Had 96 Elantra Wagon
Ahh and the Video, This is the 354whp pull I didn't have the 359whp pull on video. This is more to show that the sheet is from my car.
Now onto the video: 354whp/274ft lbs
Not a bad number. But you really need to find a way to spool that thing up quicker or raise the rev limiter another 1k to make that power usable. The HP curve is still climbing when you hit the limiter and didn't get "decent" power til 5500rpm.
Have you built the head yet?
The turbo spools nicely (for me anyways), but this isn't a street car for say. hehehe
And the reason I let off is because it was leaning out. So there is alot more power and there will be a new number come friday. Yes still bone stock head.
tim, ever thought of a bit of nitrous to help the thing spool up, and cut off at a certain rpm, like computer controlled nitrous, i think that haltech has a setting for that? or no?
if you could even get that thing spooled 1000 rpms lower it would be nuts..
and if you would build the head up and raise the rev limiter to ~7500 you could prob. be pushing 375whp with that same tune.
whats your AFR look like across the board? 12:1? richer? leaner?
no it went 13.5 lean and still made that power and that was due to a botched setting that I didn't catch till I was reviewing the logs. it is fixed now and will make even more power once I get it in the 11.8 range. I project on that psi with actual fuel it will make over 380.
