Found this while looking for HP to Kw convertor.
Just add planned PSI at manifold along with N/A power at the Flywheel, then hit calculate. 140 Hp (104Kw) + 10Psi = 235 Hp (175Kw) http://www.csgnetwork.com/blowerhpcalc.html |
SWEET! good find!
Meh I guess its close.
those things are kinda cool, but there are SOOO many factors into how much hp you are going to push; tuning, turbo size, efficiency of intercooler, flow of exhaust manifold, etc. etc..
seems like it would be close though. i think from the looks of some turbo setups on here, 8psi has been somewhat consistent with 210-220whp. |
<div class='quotetop'>QUOTE (hamhead @ Dec 19 2006, 12:56 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Meh I guess its close.</div>
Calculates an estimate...........not an exact figure. |
yeah, its an "ok" guess, only problem is, even if it were dead on, can it tell you WHERE it makes that power?
it's a good start on figuring out your setup based on your hp goals
| All times are GMT -6. The time now is 01:03 AM. |
