Help me find injectors best for RD Tiburon..
Old Feb 19, 2005 | 10:29 PM
2race4REAL's Avatar
Default Help me find injectors best for RD Tiburon..
Need injectors from 570cc ~ 850cc for Hyundai Tiburon.
Please give me your recommendations.
Old Feb 19, 2005 | 10:54 PM
MAXXTIB's Avatar
You could try these http://www.jegs.com/cgi-bin/ncommerce3/Pro...120&prmenbr=361 they are low impadence and in that size thats the only way you'll find them, but if your running injectors that big you'll be using a standalone anyway, They will replace the stock ones without modification.
these will also work http://www.jegs.com/cgi-bin/ncommerce3/Pro...262&prmenbr=361 They have 50lb/h that are 525cc and high impadence.
I have a set of 440cc if you could use those , I need something smaller and will trade for something from 315~360.
Old Feb 19, 2005 | 10:57 PM
a_gut's Avatar
I don't think there are many saturated injectors available at that flow rate. I'd personally get some dsm injectors and a resistor box, if anyone can confirm dsm injectors will fit.
Old Feb 19, 2005 | 11:18 PM
OdessitPashka's Avatar
can you have low impadence? if so, PM me.
Old Feb 20, 2005 | 09:02 AM
well, maybe he doesn't have a problem with doing it.
Old Feb 20, 2005 | 09:10 AM
Yeah. He said that he needs big injectors and the highest high imp. that I know of is 50lbs. So if he really wants to go that high he will have to deal with low imp. and will have to add a new resistor box.
Old Feb 20, 2005 | 02:40 PM
MAXXTIB's Avatar
High or low should not matter since there is no way you will be able to control an injector of that size with the stock ECU no matter what piggyback you run, the max we can run with our stock ECU and a piggyback is 440cc and you will still be quite rich at idle, And in order to hit the HP that thos einjectors are meant for you will need to go standalone and most standalone can run either high or low impadance injectors.
