Ferriday Engineering decompression plate?
Anybody heard about/use Ferriday Engineering decompression plate? It's copper and to lower compression ratio is used with conventional head gasket.
Thicknesses are 0.9mm, 1.2mm, 1.5mm, 2.0mm, 2.5mm & 3mm, with prices from 84GBP to 196GBP. What do you think about it? |
I have never heard of them, do they have a website or at least somewhere that we can read more info.
With the current exchange rate those are between $160-$370 US. |
They are in UK and they can do copper gasket (spacer) for Tib.
link: www.ferriday.co.uk INFO they sent to me: (sorry for loooong post) ---------------------------------------------------------------- Solid Copper Head Gaskets Compared with a composite head gasket, the solid copper version has both good & bad points. Its main strengths are that copper is a near perfect heat conductor, and that a “blow-out” is almost impossible even with high turbo boost & nitrous oxide. On the down side, solid copper is almost incapable of sealing either combustion or water & oil pressure by itself! It is the same thickness at all points, and will not “fill” variations between block & cylinder head surfaces in the way that a soft composite gasket can (so the thickness of the copper will not have any effect on its sealing ability). Both the cylinder block & head must be completely flat, with the best surface finish you can achieve. Failure to ensure this will lead to gasket failure. Sealing combustion pressure - There must be some device present to create extra clamping pressure around the cylinder bore. Choices include - Wire rings - A groove of a certain width & depth is machined into the block concentric with the bore. E.g. – a 39 thou wide, 35 thou deep groove will accept 40 thou solid wire to give a snug fit and 5 thou protrusion. I would suggest setting wire protrusion to be approx 10% of copper gasket thickness. (Not suitable for blocks fitted with thin wall liners). Ferriday Sealing Rings (FSR, Patent applied for) - A special Stainless Steel sealing ring is laid on top of the copper gasket to create extra clamping load. Each ring has 3 “ears” that locate into corresponding holes in the copper gasket for ease of assembly; clamping forces then keep the FSR’s in place. FSR’s are much cheaper than Wills rings, may be re-usable providing they are not damaged, and are compatible with blocks fitted with thin wall liners. Wills Rings - Are available in various sizes and are often gas-filled. These have been regarded as the ultimate in cylinder sealing & can be found in some F1 engines. A substantial groove must be machined into the block or head - width & depth work in a similar way to wire grooves (see above). Wills rings are relatively expensive and sometimes have to be made to order, some engines will not have enough space between the cylinders to accommodate the ring. It is possible to use the copper gasket as a “carrier” for the Wills rings and so avoid machining a groove. Please contact me for more details. Liner heights (Wet Liner Engines Only) - If the liner height is set to around 3 “thou” above the block face, then this will create the same clamping load as Stainless Steel rings (or machine the liners flush with the block deck & use Ferriday FSR’s) Annealing – Not everyone considers annealing to be essential, and some have simply used the gasket as it is. I would suggest that annealing cannot do any harm, and may be beneficial. Hang the gasket on a wire hook, and use a blowtorch (not Oxy-Acetylene - too hot!) to heat the copper until it is cherry red. Start at the bottom and work upwards, preferably in a dark room for easy visibility, until the entire gasket has been treated. Allow to cool slowly! Do not quench, bead-blast or bend the gasket. Remove oxidation with fine wire wool. Assembly Suggestions for FSR’s, and Water & Oil Passages - Place the FSR’s onto the copper gasket & bend the locating “ears” into the corresponding holes on the gasket – use a ballpoint pen or similar. Remove the FSR’s until later. A layer of modern chemical sealant is usually enough to seal the oil & water galleries. My choice is a high temperature soft silicone similar to that found on mass produced gaskets. WellSeal, Hylomar Universal Blue, and VHT Copper Gasket Cement also work well. Apply a bead of sealant around each water & oil passage on both sides of the head gasket, but be careful not to let any particles or bits of debris attach themselves to the sticky sealant. Place the copper gasket onto the block, ensuring it is the right way up ( ! ), and put the FSR’s into their correct position. Assemble the head following the usual tightening sequence & torque pressure. Follow the bolt manufacturers torque instructions, but be sure to lubricate the threads & underside of the bolt head. If using conventional bolts (not stretch) I would suggest re-checking bolt torque after the initial warm-up period, then again after a period of running. A micro-thin copper gasket or rubber 0-rings can be used to help seal pressurised oil galleries and other problem areas – please ask for more details. Is A Copper Head Gasket The Right Choice? - Solid Copper can be especially useful for high-powered engines that have suffered failures with conventional gaskets, and should be considered a hard-core competition component. Although a similar formula can be applied to most head gaskets, what works well for one engine may not be suitable for other applications; the right combination of sealant, liner protrusion, oil pressure sealing, bolt type & bolt torque must be found to achieve the desired results. No suggestion or guarantee is made that a slab of solid Copper will sort out your cylinder sealing problems, though copper gaskets with FSR’s have proven to be successful in applications where other gasket solutions have failed. Danny Kirk suffered failures with all gasket types in his high power Cosworth YB engine, but has found the FSR system to be completely reliable while running 11.1 second standing quarters! After over 100 drag-strip runs, plus road driving, Danny has re-used both the head gasket & sealing rings when he did a “freshen-up” engine rebuild. Help over the phone is available should you need it - speak to Mike Tanski on 01785 621710. Using the Copper Gasket as a Decompression (Spacer) Plate - If you are using a copper gasket as a spacer plate to lower the compression ratio of a turbocharged engine, then sealing is much simpler. All that is needed to seal the copper plate against the block is a thin smear of sealant around the water & oil galleries between the spacer plate & block only. Place the conventional head gasket on top and let it do its job in exactly the same way as if the spacer plate wasn’t there. Don’t forget that with OHC engines it may be necessary to use a vernier pulley to allow correct cam timing settings. The difference between a Decompression Plate and a Solid Copper Head Gasket – is very little. These two items are essentially the same (i.e. a copy of the original head gasket), although the solid copper head gasket has extra locating holes machined for Ferriday Sealing Rings. A solid copper head gasket is needed when a conventional head gasket is not strong enough for the amount of power a modified engine can produce. A decompression plate can be used as well as the conventional gasket to reduce compression ratio, or restore piston to valve clearance on heads that have been heavily skimmed. The plate simply becomes an extension of the block and allows the head gasket to do its job in the normal manner. Sealing rings do not need to be used with decomp plates. |
Sounds good, if we can get some soild pricing on each thickness I think this would be helpful to those that don't wish to put pistons in to lower compression.
