Dual exhaust on a turbo
Old Jan 4, 2012 | 12:17 PM
Matrix905's Avatar
Vehicle: 2005 Elantra
Default Dual exhaust on a turbo
I see that people upgrade the diameter of their exhaust piping when going turbo. What if you kept the stock diameter (2”) but did a dual exhaust as a true duel or with an x-pipe. Would it equal the same performance as say a 3” diameter pipe upgrade?
Old Jan 4, 2012 | 09:16 PM
Dual exhaust on anything less than an 8 cylinder engine is rice.
If you are getting custom pipes made, why would you not go a little bigger?
Old Jan 4, 2012 | 09:59 PM
300D50's Avatar
Dual exhaust done right can sound quite nice on a 4 banger.
Old Jan 5, 2012 | 06:18 AM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
An exhaust system is only as good as its smallest section especially on a turbo engine. Turbos love zero back pressure so as close as you can get to that target the better. Say you had a nice sized turbo with a 3" downpipe that then necked down to a 2" exhaust system. You effectively have a 2" system and it will choke the turbo. If you want the look of a dual set up you can just branch off a pipe after the axle and throw another tip on the other side. This way it won't bottleneck the system and give you the look your after.
