do sandwich plates work
Does sandwich plates work well for oil gauges and a feed line for turbo?
Originally Posted by Wolfie
(Post 710328)
They work well for oil coolers providing you have one with a thermostat. I wouldn't recommend using one for the turbo oil feed as you won't have significant pressure at the oil filter... You have a couple of threaded bungs in the head which can be removed to fit -an braided lines. You could possibly use it for the oil return but I'm all for the 'do it once and do it proper' after having wasted $$$$ on trying to find cheap solutions to a problem which has already been solved by other members of the tiburon community. |
