Re: *Exhaust Listings* Currently Available...
Hey, i was just wondering if there is any difference between the T3/T4 made by garrett vs the T3/T4 made by turbonetics? Im wondering this because i was planning on getting the T3/T4 (garrett) but im thinking i want a ball bearing turbo because of the fact that they spool faster...... Turbonetics T3/T4 gives you the option of ordering it as a ball bearing set up. should i go with Garrett or turbonetics? or chose a different BB turbo?
Re: 180 Km Top Speed???
I think that the main difference is the Brand.... You will get better luck rebuilding a Garret Turbo than a Turbonetics.... :? :?
Re: More Rice!!!!
turbonetics will use better designed/plished compressor wheels which will have a larger inlet/outlet... they also use better compressor wheels
